Go to Post That makes it a winning move to, well, win. - EricH [more]
Unread 11-02-2005, 17:08
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
Camera stops working when we use camera_set_servos()...
Ok so we're trying to make our camera pan back and forth until it sees the vision tetra, then lock and track. However it appears that whenever we call camera_set_servos() it stops searching for a color, and when we tell it to look for a color ( camera_find_color() ) it then appears to recenter the servos; we're stuck. Is there any solution to our problem?
This code block is inside Camera_Processing(), before it's own tracking routine.
  if(!tracking)
    camera_set_servos(cnt,128);
    cnt += dir;
    if(cnt == 210)
      dir = -5;
    else if(cnt == 40)
      dir = 5;
    printf("Didn't find it: %d\r",cnt);
Now, when we had it in other places using 'if(cam.conf < 60)' or something similar to track it, we had the same problem. I believe the problem with the reseting servos, is using camera_reset() in camera_find_color(). But, the real problem, IMO, is the mysterious breaking of the camera while using camera_stop() (and therefore camera_getACK(), while using camera_set_servos). I really hope it's something really silly.
Unread 11-02-2005, 18:18
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Camera stops working when we use camera_set_servos()...
After you set the servos, you have to tell the camera to track again.
Unread 11-02-2005, 18:20
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
I have the same problem. Today I am going to try an idea proposed somewhere around here to use a left, right, and center position and spend a few seconds at each. I dont know if it will work, and assuming that the conclusion you came to (that resetting the camera centers the servos) it wont work, but its worth a try.
Unread 11-02-2005, 18:27
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
That cause the servos to recenter though, meaning we can't pan and look for a colr at the same time, cause it keeps recentering when we tell it to look for colors. Which makes pan useless..but without it we can't see the tetras in most cases and we're against the idea of moving our robot if we can avoid it.
Matt Krass
Unread 11-02-2005, 18:42
russell's Avatar
#1430 (WRONG)
Has anyone tried using camera_set_servos() without stopping the camera or auto servos or any of that? I know it says you can't do anything other than camera_track_update() after camera_find_color(), but has anyone tried it anyway?
Unread 11-02-2005, 19:01
Matt Krass's Avatar
AKA: Dark Ages
It works, but it calls camera_stop() in camera_set_servos(), which interestingly enough makes it stop..everything, color tracking included. Without camera_stop() it jsut seizes up the camera.
Matt Krass
Unread 12-02-2005, 03:34
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
just an idea, but.....
what if:
1)you took the pwm out on the camera, and connected that to the pwn in on the robot controller.
2)connected a pwm out from the robot controller to the servos on thecamera mount.
now all you need to do is decide on the software level when you want to track and when you want to keep panning.
if (!tracking) //if the caera isn't trying to track - pan
    pwm_15=cnt;
    cnt += dir;
    if(cnt >= 210)
      dir = -5;
    else if(cnt <= 40)
      dir = 5;
else if (tracking) //if the camera is trying to track, give the servos it's values.
    pwm_15=pwm_in15;
one problem might be that the camera wouldnt know where it started, and if it needs its current location to move the servos correctly, you would need to compensate somehow:
    pwm_15=(cnt-127)+pwm_in15; //if the camera expects to start from 127, then you need to compenstae, because it thinks it's starting at a different place.....
(cnt-127) gives you the offset....
just my 0.02 NIS (New Israeli Shekel)
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 12-02-2005, 08:43
Matt Krass's Avatar
AKA: Dark Ages
Well as far as I am informed, the cameras servos must remain connected to the camera and the camera only, so that's out...Any other ideas?
Matt Krass
Unread 12-02-2005, 11:35
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
says who?
is this in the rules or something? if it is, sounds like a rule meant to make it harder on us....
i'll go look this up now....
-Paraphrasing JFK
Unread 12-02-2005, 12:57
Calvin Calvin is offline
Calvin has a spectacular aura aboutCalvin has a spectacular aura about
ID: 1183 Section: 5.3 Status: Answered Date Answered: 1/17/2005
Q: May we connect servos to the PWM outputs on the CMUcam to take advantage of the automatic pan and tilt control that it provides
A: Yes. Servos connected to the camera module are considered part of the camera module and can only be connected to it.
That "only," makes it sound like no.
Unread 12-02-2005, 18:45
Bleric's Avatar
Bleric Bleric is offline
#0624 (CRyptonite)
Bleric is on a distinguished road
Send a message via AIM to Bleric Send a message via MSN to Bleric
So... no one has figured out how to make the camera pan back and forth to look for a color?
I'm working on the problem myself, without much success. >.< If I figure anything out, I'll let ya know, but... right now it looks like we'll just be turning the whole robot back and forth if the tetra isn't in the camera's field of vision. :
Unread 12-02-2005, 20:33
logicalhippo logicalhippo is offline
AKA: Russell McClellan
#0213 (Dirty Birds)
logicalhippo is an unknown quantity at this point
Send a message via AIM to logicalhippo
NOPE! check out question 1480:
Q: Is it illegal to use the RC to control servos that control the camera?
A: No.
Unread 12-02-2005, 20:57
russell's Avatar
#1430 (WRONG)
What I have been trying to do just now is something that was proposed elsewhere... foget who suggested it, but the point is this is not my own idea. But basically you plug the camera servos into the RC then set auto servos on the camera, then on the RC you check the supposed servo postions and then set the servos to those positions using the pwm outputs. It should work, but there is something wrong with my compiler. Or maybe my program. Something is wrong.
Unread 12-02-2005, 22:05
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
We're having the same trouble. If we plugged the pan/tilt into the RC wouldn't that make the camera_auto_servo not work?
http://www.mikesorrenti.com/
Unread 12-02-2005, 23:34
russell's Avatar
#1430 (WRONG)
I dont think so. My guess is that the autoservo function just sets the servo ports to the values it wants the servos at, and doesnt actually check to see that the servos are functioning. Then when you retrieve data from the camera it will tell you the positions the servos should be in, then you use that info to put them into those positions. It seems workable to me.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Camera not working when connected to robot MarkVH Programming 5 14-02-2005 15:40
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
