Go to Post Awesome doesn't even scratch the surface here folks. - DonRotolo [more]
Unread 12-02-2005, 12:57
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Hall effect sensor Filtering
Hi,
I have read about filtering the Hall Effect sensor. I still dont understand the whole setup. Can some one please tell me which wire and resistors go to which exact pins. I will really appreciate it.
Unread 13-02-2005, 00:22
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Hall effect sensor Filtering
I am definitely NOT an EE, so I may have it all wrong, but I think the filtering you're talking about only applies to ANALOG devices. The Hall effect gear tooth sensor is a digital sensor, so I don't think it applies.
Unread 13-02-2005, 07:24
Electrical Engineer
Rookie Year: 1995
We are using the Hall Effect sensors without filtering and it works just fine.
I would only filter if you encounter a problem... JMHO...
Mike Betts
As easy as 355/113...
Unread 13-02-2005, 09:18
Jigar Patel
AKA: Jigar Patel
Exclamation Re: Hall effect sensor Filtering
Yeah but what i heard is you need to place a 20 Ohms or 500 ohms resistor to filter the noise. I don't know anything about it and I heard people saying that so I was just wondering if it is necessary to place the resistor and if yes than where? Thanks guys for your reply
Unread 13-02-2005, 10:22
Have you read the data sheet? http://www2.usfirst.org/2005comp/Specs/gths1.pdf
Obviously someone you trust has told you they are necessary, or you wouldn't still be questioning it after 2 people have said they aren't necessary in this thread. You could ask these people to fight to the death, and use the winner's suggestion, however I don't think that is likely.
Just asking if they are necessary isn't likely to help you make up your mind any better then you already have. A better question would be to ask what type of analysis did people do to decide that they were or were not necessary. From there you can make your decision on which argument seems more complete.
For the record, it can be just as necessary to filter a digital signal as an analog signal, particularly a high speed one.
Unread 13-02-2005, 11:23
The low-value resistor is for filtering any noise on the power input to the sensor. It needs to be accompanied by a capacitor to ground at the power pin in order to do any actual filtering.
The five volt power supply from the Robot Controller is pretty clean, and probably doesn't need to be filtered. The RC digital inputs are of low enough impedance that the output signal from the sensor probably doesn't need to be filtered either. Unless you're running the wires from the RC to the sensor in parallel with motor power leads, I wouldn't expect you to have any noise problems.
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Where to place Hall Effect Sensors. Moloch Electrical 10 11-02-2005 16:47
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
