Go to Post If full body suits can be made to fit properly, why do we have so many robots with saggy bumper covers? - GaryVoshol [more]
Unread 12-02-2005, 14:13
Transporter08's Avatar
Transporter08 Transporter08 is offline
AKA: Josh R.
#1502 (Technical Difficulties)
Transporter08 is an unknown quantity at this point
Send a message via AIM to Transporter08
Loop execution time for Autonomous code
I know that the speed of execution for a non-autonomous code loop is 26.2 ms, but I jcan't find documentation of how long an autonomous code will take to loop. What is the correct time, for counter purposes?
Time is like a tortoise, its slow but will always pass.
Unread 12-02-2005, 14:22
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Loop execution time for Autonomous code
If you look at the code, it shows the autonomous mode and the non-autonomous mode called at the same time, so I am pretty sure it is the same time for a loop in autonomous mode as it is in non-autonomous mode.
they might be off by a microsecond or two, because of the functions called, but they're basically the same
- from B B frank
Unread 13-02-2005, 16:17
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
If you look at the beginning of User_Autonomous_Code() you see
while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
the non-autonomous mode code only excecutes on the first cycle of the autonomous mode, after that, it is in that loop there.
So that gets executed every 26.2ms, and Process_Data_From_Master_uP() is not.
I'm not sure what you are asking, do you want to know how long it takes for the code to run?
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
Arm Rotation (1 Button Programming!!) Joelster Technical Discussion 1 14-02-2002 13:15
