Go to Post Also you NEVER need to apologize for asking questions. Asking questions is how you learn. - akoscielski3 [more]
Unread 12-02-2005, 15:25
incognito_NICK's Avatar
incognito_NICK incognito_NICK is offline
hidden in the corner
AKA: Nick Ferreira
#0179 (Children of the swamp (swampthing))
incognito_NICK will become famous soon enough
Send a message via ICQ to incognito_NICK Send a message via AIM to incognito_NICK
Question coding a potentiometer
I am trying to look at the values i get with a potentiometer through the dashboard, but my attempts are ending in failure.
So is there some special code that have to put in so that i can read it or is it because i have it plugged in the wrong spot.
anyone know the solution?
Unread 12-02-2005, 15:35
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: coding a potentiometer
on your pot you should have 3 pins, i blieve that the two outer ones should be connected to the + and - pins of the analog inputs and the middle one to the signal pin. (not infront of the robot right now...)
once you do that use this code: (assuming you connected it to analog input #1)
pot1=Get_Analog_Value(rc_ana_in01);
printf("pot1=%d \r ",pot1);
i'm not sure if you can read the analog inputs with the dashboard....
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 12-02-2005, 15:53
Do you have to pot attached to the OI or attached to the RC?
You could have a wiring problem with the pot in either place, so double check the OI or RC specs for correct wiring.
The dashboard display for the OI comes setup to show the joystick port pot values as a range from 0-254.
For the RC dashboard screen you'll have to scale the pot (0-1023) to the range (0-255) and set one of the User_Byte's (1-6) to that value.
Unread 12-02-2005, 23:05
Or use two user bytes:
    User_Byte1 = value >> 8;
    User_Byte2 = value & 255;
Unread 12-02-2005, 23:28
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Just bitshift it twice (from a 10 bit to an 8 bit number)
POT = Get_Analog_Value(rc_ana_in01) >> 2;
http://www.mikesorrenti.com/
Unread 14-02-2005, 15:56
AKA: Nick Ferreira
thanks, that situation has been taken care off. appreciate greatly.
PHP Coding HELP!!! FRANK(WGH) Website Design/Showcase 9 26-01-2005 17:18
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
Coding / Style Standards for sharing C code Joe Johnson Programming 33 01-05-2004 15:15
Potentiometer Problem Greg General Forum 1 15-02-2003 18:10
