Go to Post A robot that can't move isn't a robot. It's just furniture. - John Neun [more]
Unread 12-02-2005, 16:04
Charley's Avatar
Charley Charley is offline
Alumnae, Capt v2 for ever.
None #1350
Charley is on a distinguished road
Send a message via AIM to Charley
Radio problems
Our team is working to hook up the radio controller to the robot controller, and it isn't quite working.
Originally, we just had to wiggle it around for a while, and make sure the screws were tight, but now it's not working all together. Has anyone else had such a problem, or should I call FIRST?
Currently we're tethering it up, but that's not going to work for long!
thanks
Team 1350
Manchester 2003 Rookie All Stars
Unread 12-02-2005, 16:12
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Re: Radio problems
Can you be a little more specific then 'isn't quiet working'? Is there a communication failure? Is it not detecting the radio or OI? Is the team number set correctly? Is there any other wireless device in the area that could be causing interferance?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 12-02-2005, 16:21
Charley's Avatar
None #1350
Re: Radio problems
Both the user radio and the robot radio say "Standby" but the motherboard has a red light for the radio controller, and the operator interface has the same. There isn't any interference in the area, we're the only ones here, and we've never had it before. Our team number's set, too.
Team 1350
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
Re: Radio problems
If you are having radio problems, you should call Innovation First. FIRST is just going to tell you to call them.
Unread 12-02-2005, 16:40
Re: Radio problems
You've had it tethered since you set the team #?
Unread 12-02-2005, 17:05
Charley's Avatar
None #1350
Re: Radio problems
Yes. When our radio stopper working, in order to test it we tethered it.
Team 1350
Unread 12-02-2005, 18:01
Re: Radio problems
Try swapping the radio cables out for fresh ones one at a time. It might be a bad connection. If you have radios from last year try swapping those in as well.
Unread 12-02-2005, 19:54
Charley's Avatar
None #1350
Re: Radio problems
We tried the ones from last year, too. The ones from last year work on last year's bot, also.
Team 1350
Unread 12-02-2005, 22:31
Re: Radio problems
I would recommend calling IFI, they know way more about their equipment then any of us.
Unread 13-02-2005, 10:20
Charley's Avatar
None #1350
Re: Radio problems
I called right after someone suggested it yesterday, thanks for all your help though.
Team 1350
Unread 13-02-2005, 12:34
Re: Radio problems
Out of curiosity and incase anyone else has a similar problem. Did you ever figure out what the problem was and what did IFI say to do to fix the problem?
Unread 15-02-2005, 09:44
Charley's Avatar
None #1350
Re: Radio problems
We re-teatherd. Though our team number said 1350 on it as it should, we had to reset all the numbers and try again. I guess ours had gotten moved around in transit.
Team 1350
Internet Radio Stations cibressus53 Chit-Chat 2 26-10-2004 00:28
Radio Problems!! Please help arpus maximus Control System 23 21-05-2004 20:30
Radio Problems KWalsh Programming 3 24-02-2004 17:25
Radio problems -- not archiver 2000 1 23-06-2002 22:23
