Go to Post It's better to be safe than sorry. - Dan Petrovic [more]
Unread 12-02-2005, 16:49
caderader's Avatar
caderader caderader is offline
caderader
#1284 (DART)
caderader is an unknown quantity at this point
need help with autonomous
Can anyone tell me the context when inserting code for autonomous i tried inserting code at the point in user_routines_fast.c where it says insert autonomous here or whatever but when i load it I can't get it to run and the ifi loader program that shows the status of the robot while your hooked up to it says "waiting for bump switch to be hit"?????? heres the code im using.
Getdata(&rxdata);
commands command_list [] = {
CMD_DRIVE(1000)
NULL
this may be stupid and way of but any help would be greatly appreciated.
Thanks
Unread 12-02-2005, 16:53
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: need help with autonomous
Make your commands in command.h, then comment the robot_control() in user_routines.c out and uncomment robot_control() in user_routines_fast.c
To test your robot in autonomous mode u need a swith connected to the Competition port. The switch basically tells the robot if autonomous is on or off.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 12-02-2005, 17:31
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
If you do not have the dongle made yet you can put your robot on blocks and set the team number to 0000 and auto mode will start when you turn it on.
our web site
Unread 14-02-2005, 18:25
caderader's Avatar
caderader
#1284 (DART)
I tried doiing what you told me about commenting certain parts and uncommenting others then changed the team number to 0000 tried my autonomous code again and it still isn't doing anything. In the IFI loaders program status window it just says "waiting for bump switch to be hit". If anyone just has some example code I would appreciate it. I don't want to copy anyones code but if someone has some example code from autonomous mode out of the user routines fast file where i would greatly appreciate it.
Wolrd Triple Play Autonomous Mode (WAM) Standards Natchez General Forum 3 11-01-2005 15:52
Next Years Game? Jeremy General Forum 49 27-04-2004 01:53
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
