Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Go Back   Chief Delphi > FIRST > General Forum > FIRST E-Mail Blast Archive
  #38   Spotlight this post!
Unread 12-02-2005, 19:59
Dr.Bot
Posts: n/a
Re: **FIRST EMAIL**/Fisher-Price Motor Information
Another option for teams electing to run the 6 volt motor is to limit the peak voltage going into the PWM to avoid over heating the motor. I tested running a Blue Victor using a 6 volt supply and it appeared to run well. I am not an EE, so I can't say if this is safe for the PWM - I would continue to run the PWM fan on a separate 12v circuit. I also am not sure if this violates some other safety/construction rule. So I'd appreciate it if an EE and someone from the rules committee would chime in. I checked on Digikey, and there are many solid state voltage regulators at 5, 6, 7 volts and up to 20 amps. There is a cheap hobbiest trick that uses 2 diodes to float the center tap of a 5 volt regulator. This should result in a 6.2 volt output on the regulated supply.
Even the 12v FP motors and transmissions tend to heat up in competition - so I would consider using a fan to cool them. A simple trick is to position the PWM near the motor so that air is always blowing over the motor.
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
Multiple Fisher Price Motors? authgeek1218 Motors 5 10-01-2003 10:48
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
