Go to Post You're part of what makes FIRST so special. - Matt Krass [more]
Unread 12-02-2005, 21:46
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Where to buy good potentiometers?
We are looking for some potentiometers that are a little more precise then the ones you get at radio shack. We also need something that will turn more then 4 revolutions. Any suggestions would be greatly appreciated.
Thanks in advanced,
Kirk Oden
Unread 12-02-2005, 22:19
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Re: Where to buy good potentiometers?
http://digikey.com
if they dont sell it, it probablly dosn't exist.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 12-02-2005, 22:22
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
I have used this Bourns Precision 10-turn Pot from Newark for years:
http://www.newark.com/NewarkWebComme...KU=01F8344&N=4
Hope that helps,
Aidan
Unread 12-02-2005, 22:23
AKA: Dr. Brooks
no team (WRRF)
Thanks in advanced,
Kirk Oden
The Radio Shack pots are quite noisy, and can momentarily open
while you turn them, leading to bad behavior. We use very nice
pots made by Bourns, available from Digikey. For the 270 degree
pot, we use Digikey part number 3852a-282-104a-nd, about $9.
For the 10 turn pot, we use Digikey part number 3541h-1-103-nd,
about $28. The particular ten turn pot is chosen so that its "value
steps" are much smoother than the quantization error of the robot
ADC. The 10 turn is a 10K ohm pot, you need to connect the
normally open end to ground through a 500 ohm resistor to avoid
the OI's jump to 127 upon seeing zero volts behavior.
I did not find a nice 100K 10 turn pot. I did look for them...
Congrats all and good luck on Saturday(Tomorrow) CrimsonDesigns Championship Event 0 16-04-2004 16:48
Dean would make a good Donald! Jessica Boucher Televised Robotics 1 13-04-2004 10:42
your favorite music and tipps about good new rock music PsychoPhil Chit-Chat 26 03-07-2002 01:19
