Go to Post But frankincense and myrrh will come in handy after your team starts to smell during that first design meeting. - Jessica Boucher [more]
Unread 13-02-2005, 11:23
Re: Hall effect sensor Filtering
Originally Posted by magical hands
Yeah but what i heard is you need to place a 20 Ohms or 500 ohms resistor to filter the noise. I don't know anything about it and I heard people saying that so I was just wondering if it is necessary to place the resistor and if yes than where? Thanks guys for your reply
The low-value resistor is for filtering any noise on the power input to the sensor. It needs to be accompanied by a capacitor to ground at the power pin in order to do any actual filtering.
The five volt power supply from the Robot Controller is pretty clean, and probably doesn't need to be filtered. The RC digital inputs are of low enough impedance that the output signal from the sensor probably doesn't need to be filtered either. Unless you're running the wires from the RC to the sensor in parallel with motor power leads, I wouldn't expect you to have any noise problems.
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Where to place Hall Effect Sensors. Moloch Electrical 10 11-02-2005 16:47
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
