Go to Post its pretty great when non FIRST friends go into your purse for chapstick or something and find a spike... - anna~marie [more]
Unread 13-02-2005, 12:19
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
code efficiency
I've got a little problem: as a part of the joystick program i need to use Pitagoras'es formula, which means square root/ each time iv'e tried using it I got an error, so I thought of a lookup table. the prolem is that the lookup table will b 65,000 values long.
whar will be better- using the function, the big tble, or mabe using some simple trigonometry which requires just one lookup table 90 values long?
help please.
also- if you could send me a picture of the three alibration colors- red, green and yellow- it'd be really wonderful for my teams- we're Israelis, and to buy a paint color we need to choose it manually- not by its colorants.
thanks in advanse
Unread 13-02-2005, 12:31
Re: code efficiency
Originally Posted by Anton
I've got a little problem: as a part of the joystick program i need to use Pitagoras'es formula, which means square root...
What do you need to do with the result? If you're just comparing it to something, you can instead compare to the square of that something and avoid taking the square root altogether.
If the result is going to be used as an integer, you can use a much smaller lookup table. Since many inputs will yield the same output, you can actually make a table of squares and search through it (using a binary search will keep it short).
Unread 13-02-2005, 13:24
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Re: code efficiency
If you need a square root function you can use this:
int intRoot(unsigned int value)
  unsigned int result = 0;
  unsigned int multiplier;
  unsigned int backup;
  int loopint;
  for (loopint = 7; loopint >= 0; loopint--)
	 multiplier = 1 << loopint;
	 backup = result;
	 result |= multiplier;
	 if (result * result > value)
		result = backup;
  if (value - result * result > abs(value - ((result + 1) * (result + 1))))
	 result++;
  return (int)result;
Note: this will only work with integers and will give you (the closest) integer aproximation of the square root of a number.
Behold the power of SPAM.
Unread 13-02-2005, 14:55
Anton's Avatar
Anton Povzner
#1581 (Element)
Talking Re: code efficiency
hry thanks!
acualy, i've just replaced my 65,000 table with one just 520 valuse long, but it was still too much for my bot
thanks again
BTW- your code has just sved me from an nervous breakdown))))))))))))
my team has just discovered that our arm won't rise... and I don't seem to care at all... surely it's just all these sleepless nights trying to get me...(need sleepy smiely... )
Unread 13-02-2005, 15:24
Anton's Avatar
Anton Povzner
#1581 (Element)
general question
another thing: what is better, generaly, a lookup table or just a function?
i know it's a bit too general, but still...
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
