Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 12-02-2005, 17:50
Team 668 Team 668 is offline
#0668 (The Apes of Wrath)
Team 668 is an unknown quantity at this point
speed controller max speed
we were testing our robot and we realized that the mototrs are way to sensitive. how do we make the max speed on the speed controllers from 255 to around 200. what is the code for that. whenever we use the triggers the robots moves and we dont want that. HELP!!!! thanks.
Unread 12-02-2005, 18:53
Re: speed controller max speed
any help plz. i kind of need the answer as quick as possible
Unread 12-02-2005, 18:57
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
yay for fellow San Jose Team. What you need to do is add a limit to the pwm values that are being sent to the speed controllers.
For instance
(insert x for the pwm number)
if(pwmX >= 200)
pwmX=200;
or
pwmX= pwmX >=200 ? 200 : pwmX;
We also added a dead band where any value +30 or the middle 127 on the joystick will not make the motors move since the joysticks are so sensitive
Harker Robotics:1072
http://www.harker-robotics.org
Unread 12-02-2005, 18:59
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
You could one of three basic things:
You could use a formula to squish things in, which may take longer, but consume less space
or you could use a lookup table, which would take less time, but consume more space.
Or you could just cut everything off after 200, which is small and takes little time.
Here is a an example fomula one:
unsigned int Limit(unsigned int pwmin)
unsigned int tmppwm = 0;
tmppwm = (unsigned int)(((pwmin-127)*72)/127) + 127);
return (tmppwm+127);
- from B B frank
Unread 13-02-2005, 12:48
how do u set the dead band because the joysticks are really sensitive? thanks for your help
Unread 13-02-2005, 12:54
AIBob's Avatar
AI Programmer
I think this is what you mean:
unsigned int DeadLimit(unsigned int pwmin)
if(((pwmin-127) && 0x7F) >15 ) return pwmin;
else return 127;
Which would make anything from 112 to 142 all to 127.
- from B B frank
Unread 13-02-2005, 13:04
it comes up with an error on the line that has the " { " on it
Unread 13-02-2005, 13:06
AIBob's Avatar
AI Programmer
What does the error say?
- from B B frank
Unread 13-02-2005, 13:11
error: syntax eror c:233. it says it when i compile it. on line 233 is the " { " after:
unsigned int deadlimit (unsigned int pwmin)
{ <--- that is where the error is
Unread 13-02-2005, 13:22
AIBob's Avatar
AI Programmer
It might be because you left a bracket open from another peice of code earlier in the code..
If that is not the problem... it might be that you did not define
"unsigned int DeadLimit(unsigned int pwmin);" in an h file for referring to it in anotehr piece of code.
- from B B frank
Unread 13-02-2005, 13:23
nvm that i figured it out but now it says pwmin has not been defined. do i just do #define or do io have to define it a different wway. thanks a lot for your help.
Unread 13-02-2005, 13:25
AIBob's Avatar
AI Programmer
no you do not need to use a define....
you should just call it as a function like so:
pwm01 = deadlimit(pwm01);
or something like that...
The pwmin is defined by the function...
be sure that you define:
inside of an h file that you have included in it.
- from B B frank
Unread 13-02-2005, 13:38
so i should add unsigned int deadlimit ..... into and h file and then the
if (((pwm-127) && 0x7f >15) return pwmin
else return 127;
into user_routines.c. where do i put the pwm01 = deadlimit(pwm01)?
Unread 13-02-2005, 13:41
im really confused right now. so if you could right it out in a post that would be really appreciated.
Unread 13-02-2005, 13:57
is there an easier way to do this because it to compile but then when it gets to the 3rd stage it says : could not find definition of symbol deadlimit in file user_routines.o
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
How to make a max speed Team 668 Programming 3 02-02-2005 17:54
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
