Go to Post If you're the smartest person in the room, you're in the wrong room! - Ian Curtis [more]
Unread 13-02-2005, 14:06
Team 668 Team 668 is offline
#0668 (The Apes of Wrath)
Team 668 is an unknown quantity at this point
joystick sensitivity
i have been tampering with the code to make joysticks less sensitive. i cannot figure it out. it either has an error or nothing responds. does any1 kniw the code to make tha joystick less sensitive
Unread 13-02-2005, 14:17
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: joystick sensitivity
I'm not really into programming, but I do know from driving the robot that our controls are also really sensitive and sometimes do get stuck so the robot moves by itself after someone has driven it. If you want to make a makeshift fix on your joystick, you can probably take apart the joystick and play around with the springs in the joystick and see if they are better or not after doing that. It might work...it might not...but good luck writing the program...
...Actually...once I think of my method...it seems really stupid...sorry.
Unread 13-02-2005, 14:22
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Are you working with the white joysticks ? If so the best thing you could do is throw them away and get some new ones. We used 1 of them last year to control our arm and i wished we hadn't. I happen to be both the programmer and the arm operator and i did the best i could to get them some what usable. Anyway here are some possibilities.
What you can do to fix this problem is put a parabola in your joystick code, this makes the beginning movements less sensitive. I think if you look through the white papers, in the programing section you'll find one on adding a parabola.
Other teams have replaced the springs to make the movement less "floppy", in return making them easier to control.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 13-02-2005, 14:38
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
One thing we did was add in a "deadband" to the center of the joysticks, which has really helped. The code makes use of an absolute value function that we created. Today, we'll also be adding a ramping function to the joysticks just like what was described above, I can get you that code too if you need it.
#define DEADBAND 10
int abs(int x)
  if (x >= 0)
    return x;
  else
    return -x;
if (abs((p1_y - 127)) < DEADBAND)
  p1_y = 127;
if (abs((p1_x - 127)) < DEADBAND)
  p1_x = 127;
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 13-02-2005, 14:51
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
#define DEADBAND 10
int abs(int x)
if (x >= 0)
return x;
else
return -x;
p1_y = 127;
p1_x = 127;
Here is something similar, only you do not need a seperate function... abs(p1_x) can be replaced with (p1_x && 0x7F), because the last bit is the sign, like so:
#define DEADBAND 10
if (((((signed int)p1_x-127) && 0x7f) < DEADBAND) p1_x=127;
if (((((signed int)p1_y-127) && 0x7f) < DEADBAND) p1_y=127;
- from B B frank
Unread 13-02-2005, 16:35
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
OK where does this code go into the rest of the default program. Can I put it anywhere in user routines.c or does it have a special place?
our web site
Unread 13-02-2005, 16:39
AIBob's Avatar
AI Programmer
You would place this code right after you read the input data from the operator interface like so:
top of the page, or in an included file:
#define DEADBAND 10
you may place this in "Default_Routine()" if it is called, right at the beginning:
or if you do not call "Default_Routine()", then place the code right after "Getdata(&rxdata);" is called
- from B B frank
Unread 13-02-2005, 17:02
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Actually, your idea is a very good one. We did it last year and this year with great success.
The deadband will solve your problem of the robot not stopping when you let the joysticks return to "center," but it doesn't help with your sensitivity problem. You can go for a full PID controller, but a low pass filter, which is basically just the P of a PID, will probably do the trick. I can get you our code from this year in an hour or two.
Unread 13-02-2005, 20:38
Originally Posted by AIBob
abs(p1_x) can be replaced with (p1_x && 0x7F), because the last bit is the sign,...
Not so. For two reasons, the first of which is very important:
Negative numbers are not stored in sign-magnitude form. They are in "two's-complement" form. The value -1 masked with 0x7F yields a value of 127, a far cry from the expected 1.
(The second reason is that && is a logical operator, giving a true or false result. The arithmetic and is represented by a single &.)
The simplest syntax I know of for an absolute value function uses the ternary if operator. It's cryptic, but effective:
(value<0?-value:value)
Unread 13-02-2005, 20:44
AIBob's Avatar
AI Programmer
Ok.... for some reason it worked for me in my code though.... but I suppose it will not work for absolute values...
Thanks for letting me know.
- from B B frank
Unread 13-02-2005, 21:01
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
For more information:
http://en.wikipedia.org/wiki/Negativ...tive_in_binary
http://en.wikipedia.org/wiki/Two%27s_complement
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 16-02-2005, 18:45
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
Thumbs up Re: joystick sensitivity
i just decreased the limit mix to the joystick drive, which should be at 2000 when to begin with, so it will move less when u move the joystick, using the normal white joysticks
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
