Go to Post We should have a rule in CD, no sad booboo faces that make you want to cry... - JaneYoung [more]
Unread 13-02-2005, 14:22
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Re: joystick sensitivity
Are you working with the white joysticks ? If so the best thing you could do is throw them away and get some new ones. We used 1 of them last year to control our arm and i wished we hadn't. I happen to be both the programmer and the arm operator and i did the best i could to get them some what usable. Anyway here are some possibilities.
What you can do to fix this problem is put a parabola in your joystick code, this makes the beginning movements less sensitive. I think if you look through the white papers, in the programing section you'll find one on adding a parabola.
Other teams have replaced the springs to make the movement less "floppy", in return making them easier to control.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
