Go to Post Our job as mentors isn't to teach them how to make a robot...It's to teach them that there is value in technology and being among the people who create it. - Andy A. [more]
Unread 13-02-2005, 15:44
Aren_Hill's Avatar
Build Nifty Things
using more motors
Is it legal for us to use 2 nippon desco window motors or has anyone found a good way to couple to it i searched but couldn't find it (rookie)
Unread 13-02-2005, 15:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
using more motors
No. You may only use the motors in the kit and only in the quantities provided.
Unread 13-02-2005, 15:52
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: using more motors
<R39> Specific items NOT allowed include:
• Batteries different from or in addition to those provided in the Kit.
• Circuit breakers different from those provided in the Kit. Note: the Snap Action brand circuit breakers provided have unique “trip” characteristics. No substitute brands are permitted.
• Electric motors different from or in addition to those in the Kit.
• Any air compressor, pressure relief valves, or air storage tanks other than those provided in the Kit.
• Hydraulic fluids or hydraulic components.
• Materials classified as hazardous by their MSD Sheets (teams should provide MSD Sheets for any materials they use that might be considered questionable during robot inspection).
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 13-02-2005, 16:12
Aren_Hill's Avatar
Build Nifty Things
thanks
Unread 13-02-2005, 16:15
Aren_Hill's Avatar
Build Nifty Things
have you found a good way to couple to the jideco motor?
Unread 13-02-2005, 17:32
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
We had one of the local machine shops make us a coupling from the inventor file one the first parts library, Warning, the inventor files for the Jideco motor are not accurate enough for this. I spent the better part of three hours with a dremmil (sp) and one of the bits the shop had used re cutting the profile to fit the gear. It only has 4 inside teeth and is made out of steel. Other good suggestions I've heard are casting one from epoxy putty. be sure and use a release agent. And using a clamp like device to grip the teeth. Also the inventor file for the van door motor is not accurate enough to make a bracket that you can bolt the van door motor to. Mounting holes are to far from the shaft by about 3/32" Good luck
Unread 13-02-2005, 17:44
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
i have an other problem, is alos about the "black" window motors, there are RR(CW right) or RL(CCW laft) lable on the motor, does anyone remember are there two RR motor or one RR and one RL on the Kit??????,( i got mix up with window motors from lest years, and i find only one RL)......If i blow up the RL motor( CCW), may i replace it if a RR window motor???????????
Team 1009
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
