Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. - Billfred [more]
Unread 13-02-2005, 16:39
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: joystick sensitivity
Originally Posted by sirbleedsalot
OK where does this code go into the rest of the default program. Can I put it anywhere in user routines.c or does it have a special place?
You would place this code right after you read the input data from the operator interface like so:
top of the page, or in an included file:
#define DEADBAND 10
you may place this in "Default_Routine()" if it is called, right at the beginning:
if (((((signed int)p1_x-127) && 0x7f) < DEADBAND) p1_x=127;
if (((((signed int)p1_y-127) && 0x7f) < DEADBAND) p1_y=127;
or if you do not call "Default_Routine()", then place the code right after "Getdata(&rxdata);" is called
- from B B frank
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
