Go to Post 7 divisions would be... interesting. - cadandcookies [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 10-02-2005, 16:13
894|mike 894|mike is offline
FRC #0894 (Chargers Robotics)
Team Role: Webmaster
894|mike will become famous soon enough
Send a message via AIM to 894|mike
team 894 site
www.chargersrobotics.com
check it out!
Unread 13-02-2005, 00:15
Re: team 894 site
Can I get any feedback please?
Unread 13-02-2005, 16:51
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Re: team 894 site
1.) Frames are too big. While frames can be done correctly, I'm not a fan of them. That's just me. I'd use the top frame for more information and make it smaller, and get rid of the whole bottom frame, most of that info can be put on the bottom of the page with most of the information.
2.) On the navigation top, some of the links end up on another line, try to fix that.
3.) Good team info section
4.) Make the middle frame bigger.
5.) What's your team nuber? I don't see it on the page on top, or anywhere else, you might want to add it so it's easy to see.
Unread 14-02-2005, 17:22
Re: team 894 site
There's only one frame. The top and bottom are all part of the index.html page, while the iframe is within the index.html page. That way, the banner and such is only loaded once.
That would be because your font size setting is higher than normal. Try pressing Control+0 if you'd like to see it on normal size.
Thanks!
By bigger, do you mean wider? If I make it any wider, users with 800x600 resolution would have to scroll across, and that's no fun.
That's a good idea. Thanks.
Thanks for the feedback.
Unread 14-02-2005, 19:54
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: team 894 site
But it gives the same effect as a top, middle and bottom frame.
You should try to make websites that work with everything - as in it doesn't matter what font size the person uses.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Team 527's Website colt527 Website Design/Showcase 4 02-01-2005 12:46
HOT Team Web Site Pat McCarthy Website Design/Showcase 6 19-05-2004 10:14
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
