Go to Post ...the great teams in FRC will probably continue to be great teams. That is because they have great people who embrace the challenge rather than whine about it. - dtengineering [more]
Unread 13-02-2005, 19:50
DivideByZero DivideByZero is offline
DivideByZero is an unknown quantity at this point
Usage of van door motor
Our team is thinking of adding the van door motor to our bot, and we're wondering: What is the process of attaching a shaft to this motor? What parts are required?
Thanks for any help.
Unread 14-02-2005, 12:39
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Re: Usage of van door motor
I have a ghetto version and less ghetto version
Ghetto Version:
Got a 1/2" brass propane pipe coupler at hardware store, drilled this out to 7/16" i.d. Got a 1/2" bore sprocket from mcmastercar, wedged this sprocket onto the coupler. Then wedged the whole thing onto the shaft with a vice. It fits so tight it doesn't need keying or set screwing!
Less Ghetto Version:
Got a 3/8" bore sprocket from mcmastercar, drill this out to 7/16" to fit on the shaft. Drill a whole for set screw in shaft, tap it, and put a set screw through the sprocket and into the shaft. May need a longer set screw for this (at hardware store). Or you can weld it to the shaft.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Van Door motor help ironjeans Motors 5 18-02-2005 11:45
Van door torque curves Bolotov Motors 1 05-02-2005 09:10
Van Door Motor Thermal Overload Protection bigqueue Motors 1 23-02-2004 07:16
Attn Wildstang: Found your van Wetzel Chit-Chat 4 21-04-2003 21:41
van door question archiver 2000 1 23-06-2002 22:27
