Go to Post If you want to use the don't ask, don't tell logic about asking then you know it is wrong. - Steve W [more]
Unread 09-02-2005, 15:11
patTeam241 patTeam241 is offline
College Student
AKA: Pat Cleary
patTeam241 will become famous soon enoughpatTeam241 will become famous soon enough
Send a message via AIM to patTeam241
Dashboard port question
Ok, I'm writing my own data capture program for the OI, which would run from the Dashboard port. The goal is to have a more versatile recorder. However, I don't know the Baud rate, Parity, number of data bits, and the stop bit. Anyone have this information? Thanks
Unread 09-02-2005, 15:29
Re: Dashboard port question
From the Dashboard Spec (dashboard-specification.pdf) in the IFI Robotics zip download.
19200 baud, No Parity, 8 data, 1 stop
Unread 09-02-2005, 17:16
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Here's another one: How can a program tell if it is recieving OI or RC packets? My best guess so far is that there are specific channels for each.
Unread 13-02-2005, 21:12
College Student
AKA: Pat Cleary
For the OI/RC difference, there is a jumper right under one of the ports, I think it's the dashboard port.
Unread 14-02-2005, 09:21
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
From what I've seen there isn't a way to differentiate between an OI frame and an RC frame. The control bytes in the OI frame are the same as a type-2 data frame. I guess you could check for the frame type and assume its OI data if you're only receiving type-2 data frames.
Unread 16-02-2005, 02:23
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
There is a way to rewrite the RC/OI dashboard progam in which you can implement a custom packet structure. This is probably way too much work with the current FRC system. I believe Innovation FIRST should consider making the dashboard progam more expandable. These changes could be adding more/less packets or different timing baud and protocol options.
For instance, You could implement a timestamp function on the RC which relays timing infromation through one of the dashboard ports to get a more real time control feedback.
~Andrew Lynch
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Dashboard Output Question jnossen Technical Discussion 5 02-02-2002 19:52
