Hi, after getting my automous scripting and autonomous camera codes working independently, I have been having quite a bit of trouble putting the two together. The problems have seemed to start coming in User_Initialization when I call Serial_Driver_Initialize() along with Initialize_Encoders() and Initialize_Gyro() (from Kevin Watson's code).
I examined this and noticed it deals with interrupts, which I have had no experience with (It's my first and only year since I'm graduating this year
). Would anyone please be able to explain to me where the conflict lies? Here is the code from the three functions:
void Serial_Driver_Initialize(void)
Initialize_uart();
(which calls this) ---v
static void Initialize_uart(void)
uword8 flush;
/* Setup the device control block (dcb) */
dcb[PROGRAM_PORT].myRCREG = &RCREG1;
dcb[PROGRAM_PORT].myTXREG = &TXREG1;
dcb[PROGRAM_PORT].portId = 1; /* setup unique ID for PROGRAM_PORT */
Reset_Control_Block(&dcb[PROGRAM_PORT]);
dcb[TTL_PORT].myRCREG = &RCREG2;
dcb[TTL_PORT].myTXREG = &TXREG2;
dcb[TTL_PORT].portId = 2; /* setup unique ID for TTL_PORT */
Reset_Control_Block(&dcb[TTL_PORT]);
/* Initialize the PROGRAM_PORT port */
#if USE_BUFFERED_PRINTF
Open1USART(USART_TX_INT_ON & USART_RX_INT_ON & USART_ASYNCH_MODE &
USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, baud_115);
#else
Open1USART(USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE &
#endif
IPR1bits.TXIP = PRIORITY;
IPR1bits.RCIP = PRIORITY;
TRISCbits.TRISC6 = 0; /*TX1 output*/
TRISCbits.TRISC7 = 1; /*RX1 input */
flush = RCREG1; /* flush data */
RXINTF = 0;
/* Initialize the TTL_PORT port */
Open2USART(USART_TX_INT_OFF & USART_RX_INT_ON & USART_ASYNCH_MODE &
IPR3bits.RC2IP = PRIORITY;
IPR3bits.TX2IP = PRIORITY;
TRISGbits.TRISG1 = 0; /*TX2 output*/
TRISGbits.TRISG2 = 1; /*RX2 input */
flush = RCREG2; /* flush data */
RXINTF2 = 0;
aBreakerWasTripped = FALSE;
void Initialize_Encoders(void)
// Initialize the left encoder's interrupt. INT2 on the user PIC18F8520
// is mapped to the interrupt one pin on the EDU-RC and digital I/O one
// on the FRC-RC.
TRISBbits.TRISB2 = 1; // make sure the RB2/INT2 pin is configured as an input [108]
INTCON3bits.INT2IP = 0; // 0: interrupt 1 is low priority (leave at 0 for IFI controllers) [91]
// 1: interrupt 1 is high priority
INTCON2bits.INTEDG2 = 1; // 0: trigger on the falling-edge [90]
// 1: trigger on the rising-edge
INTCON3bits.INT2IE = 1; // 0: disable interrupt 1 [91]
// 1: enable interrupt 1
// Initialize the right encoder's interrupt. INT3 on the user PIC18F8520
// is mapped to the interrupt two pin on the EDU-RC and digital I/O two
// on the FRC-RC.
TRISBbits.TRISB3 = 1; // make sure the RB3/CCP2/INT3 pin is configured as an input [108]
INTCON2bits.INT3IP = 0; // 0: interrupt 2 is low priority (leave at 0 for IFI controllers) [90]
// 1: interrupt 2 is high priority
INTCON2bits.INTEDG3 = 1; // 0: trigger on the falling-edge [90]
INTCON3bits.INT3IE = 1; // 0: disable interrupt 2 [91]
// 1: enable interrupt 2
Initialize_Gyro()
void Initialize_Gyro(void)
// reset the heading angle
Reset_Gyro_Angle();
// force a gyro bias calculation
Calc_Gyro_Bias();
// initialize the analog to digital converter
Initialize_ADC();
// initialize and start timer 2
Initialize_Timer_2();
Then Initialize_Timer_2() does this:
void Initialize_Timer_2(void)
// use these parameters for a 200Hz gyro sample rate
#ifdef GYRO_SAMPLE_RATE_200HZ
// use a 1:16 prescaler
T2CONbits.T2CKPS0 = 0;
T2CONbits.T2CKPS1 = 1;
PR2 = 221; // 223.21 - 2 is ideal
// use a 1:14 postscaler
T2CONbits.T2OUTPS0 = 1;
T2CONbits.T2OUTPS1 = 0;
T2CONbits.T2OUTPS2 = 1;
T2CONbits.T2OUTPS3 = 1;
#endif
// use these parameters for a 400Hz gyro sample rate
#ifdef GYRO_SAMPLE_RATE_400HZ
PR2 = 140; // 142.05 - 2 is ideal
// use a 1:11 postscaler
T2CONbits.T2OUTPS0 = 0;
T2CONbits.T2OUTPS1 = 1;
T2CONbits.T2OUTPS2 = 0;
#endif
// use these parameters for a 800Hz gyro sample rate
#ifdef GYRO_SAMPLE_RATE_800HZ
PR2 = 69; // 71.02 - 2 is ideal
#endif
// use these parameters for a 1600Hz gyro sample rate
#ifdef GYRO_SAMPLE_RATE_1600HZ
// use a 1:4 prescaler
T2CONbits.T2CKPS0 = 1;
T2CONbits.T2CKPS1 = 0;
PR2 = 140; //142.05 - 2 is ideal
#endif
// make sure the timer 2 register starts at zero
TMR2 = 0x00;
// timer 2 interrupt is low priority
IPR1bits.TMR2IP = 0;
// to prevent a spurious interrupt, make sure the interrupt flag is reset
PIR1bits.TMR2IF = 0;
// enable the timer 2 interrupt
PIE1bits.TMR2IE = 1;
// enable timer 2
T2CONbits.TMR2ON = 1;
Ok well.. thank you very much for any help you have to offer.
