Go to Post Wishes and dreams can hold a robot together just as well as nuts and bolts. - Kyle [more]
Unread 14-02-2005, 03:09
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Using Interrupts
I'm having problems using interupts...
i don't understand them....
i have read the manual from IFI, and read kevin's code, but i still can't really get how is should use them.....
could someone please post a bit of code showing how to use kevin's interrupts?
Thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 14-02-2005, 07:22
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Re: Using Interrupts
hi,
what do you need the interrupts for? usually encoders. if so, take a look at Mr. Watson's encoder template. It has interrupts already set up for left and right drives. all you have to do is call the functions. also, take a look here. this is where I was utterly confused about encoders.
http://www.chiefdelphi.com/forums/sh...hlight=encoder
Processing pre-set Interrupts Tom Bottiglieri Programming 1 13-02-2005 15:41
Interrupts and Script Conundrums Jon236 Programming 2 08-02-2005 23:01
White Paper Discuss: Interrupts for Dummies CD47-Bot Extra Discussion 5 29-01-2005 03:24
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
