Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Unread 12-02-2005, 21:27
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Could a magnetic field around CIMs cause fuses to blow?
Originally Posted by Bduggan04
From experience, problems can often be fixed by fixing seemingly unrelated problems. I would advise that you try the following. It is what I would do if I was there.
Set a multimeter to Ohms
Put one probe on the frame. Use the other probe to check other spots on the robot such as the terminals of speed controllers. They should be isolated, but I suspect they are not.
You should also try removing all of the motors from the output side of the speed controllers and make sure the terminals are not touching the robot. The problem lies on the output side of the victors.
Another thing you may want to consider is that you could have mixed the motor wires up. The fuses could be blowing because the motors are running in opposite directions in the same gear box.
We'll try it, along with the magnetic field thing, but the moters seem wired right. Unless they put the wires backwards on the moter itself.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 12-02-2005, 21:28
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
To test this, remove all of the motor wires but the ones going to one motor. Run it and see which direction the wheels move. Then, disconnect it and run a different motor similarly, if they run the same direction, attach both motors to their speed controllers. Do this for both gear boxes. If one motor in a given gear box runs in a different direction than the other, reverse the polarity or revise the program.
We are certain the motors are running in the same direction in the same gearbox, each gearbox alone ran fine. However, the shorts could still be a problem, we will have to check monday.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 12-02-2005, 21:33
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
It won't hurt to double check it. I've had it happen and it will seem to work fine, but It really isn't. You could probably use an ammeter to check for excessive current draw as well. Good luck, hope I was able to help.
Unread 12-02-2005, 21:36
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
<anouncer voice> Will team 617 discover the problem with their victors in time? Will they have to do something drastic?! Tune in Monday afternoon to see the exciting conclution to this perplexing problem! </anouncer voice>
// random()
Unread 12-02-2005, 21:37
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
One problem i suspect is you may be using the wrong equiptment with the cim motors. With the Atwood/CIM motors you should use the victor motor controllers between the power source and the motors (which you are using) but what should be bridging from the battery to the victor is a 40amp self resetting circuit breaker. You should only have fuses in the Spike Relays. Below you should be using the ones on the far right at the top of the breaker board for the cim motors.
-Michael Dessingue
Unread 12-02-2005, 21:40
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
I'm pretty sure they're doing that. Regardless, the motors shouldn't draw enough to trip the breaker (or a 20 amp fuse) when it is off the ground. It probably shouldn't draw more than 6-8 amps. You should read the entire thread, the breaker tripping is the result of the problem, not its cause.
Unread 12-02-2005, 21:43
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
We are using the 40A self resetting circuit breaker, but becuase theres the breaker panel and the main breaker, we say fuses because they are like the old fuses. They look like them and the almost work like them. The big difference is that they do reset and so you don't usually need to replace them.
// random()
Unread 12-02-2005, 21:46
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
if infact you have 4 wheel drive and too much traction the motors will stall and the breakers will pop
Unread 12-02-2005, 21:50
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
It's two wheel dirve and it's off the ground so there isn't any load except the transmission and the chain.
// random()
Unread 12-02-2005, 23:08
OK,
First things first. You first picture clearly shows a wire going to the gearbox and it looks strangely like the red lead of a Chalupa motor. This is a big no no and you will not be able to compete with this arrangement. Next you have a screw missing from motor(+) on one of the controllers which leads me to believe you using a common ground or are wiring motors in series. This is also not allowed and will not work if you plan on backing up. The motor leads on the controllers change polarity, i.e. sometimes the motor(-) is battery negative and sometimes it is battery positive. Lastly, as someone has pointed out, the mounting hardware on your controllers is touching motor(-) again giving a sneak path to frame. 4-40 allen screws work OK but tywraps work and are non conductive.
So what was happening? If all is as I surmise above, the motors on the left side are reversed so that the robot can drive forward. With the polarity reversed and the motor and controllers touching the frame, the output of the left side controllers are shorted when driving forward. The opposite condition would be the case if you were driving backward. Make the suggested fixes and try again. That is how the LEDs on the disconnected controllers were lighting when you ran the right side.
As to the question about magnetic fields...the answer is no. Yes a wire in the presence of a magnetic field may have current induced in the wire. This is dependent on two things, the magnitude of the field and the field must be changing or the wire moving. Since the motor is a permanent magnet, the field is not changing, and since the wire is not moving there can be no current induced in the wire. Since the motor leads are connected to a fairly low impedance, any induced current would be tiny compared to the motor run current.
If you have any further questions you can always PM me. I won't have an immediate answer but I will get back to you. Anyone can ask me questions and I will try to answer.
Unread 13-02-2005, 13:45
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
This isn't criticism, only addressing all of your concerns.
Originally Posted by Al Skierkiewicz
OK,
The wire that looks like it is going to the gear box is just diconnected from anything. it looks like it is on the gear box but it is just over it. But it does look like it.
The screw is out becuase we were disconnecting things, and we pulled the wire out for that moter.
We see that, and we will check it out when we get back to check the robot. but it would seem odd that several wires would be doing the same thing and creating this problem
I agree that it is far fetched, but when isolating everything, that was about the only thing we could think of at the time. As far as no magnetic field changing, some magnet has to be moving for the moter to go. But it still seems unlikely.
Thanks for you help. All options will be considered. We will look at everyting on Monday when we get back to school.
// random()
Unread 13-02-2005, 20:37
Believe me there is no moving magnet. All of the KOP motors have stationary, permanent magnets. The Chalupas have two large curved magnets inside the case and glued to the case to keep them from moving. The armatures move when current is applied to them but the magnetic field lines up with the filed of the permanent magnets for the most part. The brushes are doing the appropriate switching to make the fields line up. If nothing else is wrong, the hardware touching the motor(-) screw is enough to cause your problem. I think if you fix the hardware you will be much further along, if not curing the defect altogether. Remember that some controllers are reversed and they are dumping current into the frame. Try this, take you meter and with the robot power removed, check for continuity from the frame to each output terminal on all your controllers. You should measure infinite resistance for every terminal. Then move the probe to measure the +12 volt lead at the output of the main breaker. It should also be infinite. Finally, measure the input to the main breaker (off Please) and you should again have a infinite resistance. If none of these tests are infinite, find where the path exists and remove it. Let me know what you find.
Unread 14-02-2005, 08:23
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
I just checked the bot. There IS a slight short with the screws in the victors. The resistance isn't infinate, but it is in the 1000 K ohms. The multimeter didn't beep when between the terminals but did between a screw and a termainal. This will be fixed, but I don't know if that was the whole problem.
I rechecked again with someone looking and found that the screws arn't conducting to the terminals. I found that while the wires are distint and not crossed, all of the positive red wires are conducting for each other. I tested from the breaker panel to the victors and all of the red are conducting from each part on the panel on the 40A fuses. I don't know how this works. I can't find any grounds anywhere near the victors. The red wires arn't connected tot he balck wires, but all of the black wires are connected together like the red ones. We are going to re-wire it to track down the culprit. If you have had trouble like this or know what is happening, this tr4ead is still going until there is a cure. In other words, We need more help
// random()
Unread 14-02-2005, 11:49
When we started testing our motors we noticed that whenever we tried to turn a fuse would blow for one of the motors in the gearbox on the left side of our robot and the right side would begin to struggle. This happend wether the robot was on the ground not. We decided that we should isolate the problem by testing one side of the robot at a time, so we pulled out the fuses for the gearbox on the left side. When we drove the motors on right side we noticed that the cooling fan on the Victor of the motor that had been blowing fuses began to spin, and the Victor's LED came on. This seemed very odd because the cooling fan only came on when we drove the rightside motors
Voodoo diagnostics is a tricky business, but I think I have a theory that fits your facts.
I assume your software is controlling two motors with a "right side" pwm signal, and the other two with a "left side" pwm signal. If you have one left side motor being controlled properly but the other one controlled with the right side signal, they will oppose one another when you try to turn, and you will trip a breaker if you're lucky. Same with the right side, though it sounds like you've never gotten it upset enough to actually trip a breaker, instead just having a motor being backdriven against its will.
If you remove the fuse for the wrong-sided motor, that motor will be turned by the other one on the same gearbox, and you'll end up with the Victor getting powered by the generated current.
You can either 1) disconnect all your motors and watch the lights on the Victors as you go from neutral to full throttle to full turn, and see which ones respond; or 2) double-check the code, the pwm cables, and the motor wires to make sure they all agree.
Since you insist your wiring is correct, your software is at fault, but it'll probably be easier to correct the problem by changing which pwm outputs your Victors are plugged into.
Unread 14-02-2005, 12:17
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Originally Posted by Alan Anderson
If you remove the fuse for the wrong-sided motor, that motor will be turned by the other one on the same gearbox, and you'll end up with the Victor getting powered by the generated current....
We removed the fuse for both moters on the one side. Somehow, the victors, suposedly disconnected from anthing when we removed the fuses, would still work when the other side, still connected, went. In testing the connections this morning, I saw that all of the reds were connected somewere. Looking at the wireing revieled that it looked OK. The wires arn't grounded to the frame or anything else. Black wires were connected to themselves but the Black and Red wires were isolated from each other and the frame.
Uh.. Should I be getting contentutiy through the breaker Panel with fuses out? I put one lead on the battery termainal and the other on a termainal for the moters. The resistance was great but I though it should be infinate.
// random()
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
Vetting and Idea: Modular Field Design... Justin General Forum 19 16-06-2004 15:46
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
What happens / why do motors stall? DanL Technical Discussion 19 21-11-2002 07:19
