Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
View Poll Results: What is your robot's maximum height (with arm(s) extended)?
1 foot 2 1.72%
2 feet 0 0%
3 feet 0 0%
4 feet 1 0.86%
5 feet 0 0%
6 feet 1 0.86%
7 feet 4 3.45%
8 feet 2 1.72%
9 feet 11 9.48%
10 feet 26 22.41%
11 feet 24 20.69%
12+ feet 45 38.79%
Voters: 116. You may not vote on this poll
Unread 03-02-2005, 13:13
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Robot height poll
About how to tall is your robot going to be? Post details if you want.
Alex
President
Team 1072 Harker Robotics
Unread 03-02-2005, 13:21
Re: Robot height poll
Triple Play is a game that encourages high reach. I would expect most robots to use the entire legal starting height of 60 inches, and expand from there once the match begins.
Our robot probably won't reach the insane heights some others will, but it still should be able to keep stacking tetras until they run out.
Unread 03-02-2005, 21:01
CRAZYMADI CRAZYMADI is offline
CRAZYMADI can only hope to improve
It was really hard to think of a mechanism, with which the arm can extend double the size of actual height. Although it took us almost three weeks to finalize the design, but we're done now.
Our team, came up with the lightest idea ever. Our Arm can extend almost 13 ft. and is only 25 lbs. CLue: Mars Rover........??? (nahh..just kiding)
Our pics will be soon available.
Unread 03-02-2005, 21:15
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
We do have an arm design that extends over twice the start height.
I put 10 ft on the poll, but we're really going to be more around 10 1/2.
Will post pics when I can.
Just remembered a bit more info, our arm is light as well. it was weighed in at 10 lbs last meeting. We are adding counter-support beams, and our actuator. I dont expect our bot to break 100 lbs (before we weigh her down!) and I dont think our arm will be over 20.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 03-02-2005, 22:09
Zippiot Zippiot is offline
punching bag
Zippiot can only hope to improve
Send a message via AIM to Zippiot
arm design can greatly affect needed height, an arm that picks up the tetra from the bottom wont need to be as high (like 22 inches shorter i believe) to get it on top of the goal, so for those of you using arms that make it over 12 feet is it safe to assume that you will pick up the tetras from the top?
Unread 04-02-2005, 00:20
AKA: Alex
Yes, but there are other advantages to picking the tetras up from the top
Alex
President
Unread 04-02-2005, 00:24
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
wow, i'm really suprised at the results of this poll. I thought we were tall, but now that i see a majority are over 12 feet. This year's game will really be something interesting to watch. I just hope you all have some anti-tipping mechanism installed because it's a long way down from 12 feet.
Unread 04-02-2005, 06:42
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We are going up. 12+ feet. Our arm goes from its folded position to fully extended in 4 secs. Very important for Autonomous Mode.
Unread 04-02-2005, 07:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
1317's amazing robot of doom (it has yet to be named, so I threw in the first thing I thought of. ), can reach up to 12 feet straight up, but will probably only be able to cap up to 10 feet.
Unread 04-02-2005, 10:37
punching bag
how fast can your bots reach full extension? our bot can spin the arm all the way around the bot (like a ferris wheel) but to go from ground to vertical takes 3 seconds (estimated with tetra on end).
Unread 04-02-2005, 12:13
AKA: Alex
We're between 3-4 seconds to full extension. Havn't actually tried it though.
Alex
President
Unread 04-02-2005, 12:56
c0m1ng3vil c0m1ng3vil is offline
c0m1ng3vil is an unknown quantity at this point
Creating an arm that can reach high enough to stack enough tetrahedrons and still remain within the size limit is a turely intriging problem. We are building a prototype though, out of Legos.
WARNING: SIGNATURE OUT OF ORDER!
Unread 04-02-2005, 15:01
Han Tzu's Avatar
Han Tzu Han Tzu is offline
Team Stander: AKA The Human Playa!
AKA: Metal Master
#0617 (Springers)
Han Tzu can only hope to improve
Our robots height? Hm...I will tell you when we finish discussing if it should be 12 or 15 ft tall.
Unread 04-02-2005, 23:41
teh main thing is not going to be the height of the arm. The time span is too small even to put the 5th tetris on the Center Goal.
This year's game actually gonna depend on the strategies, the three teams will use to represent themselves as one.
Unread 14-02-2005, 09:14
Aren_Hill's Avatar
Build Nifty Things
I think it will be real important the height of the bot because teams are gonna be fighting for the center the whole match who knows how high it will get. and what if you want to be able to stack from say 7ft away were able to our arm reaches 15ft straight up and i think thats a great advantage
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
Righting a robot... archiver 2001 2 24-06-2002 00:26
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
