Go to Post At this point (after shipping the robot), I'm really looking forward to doing laundry, eating a square meal, and getting to bed at a reasonable hour. - Emily Pease [more]
Unread 13-02-2005, 17:03
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
Joysticks....
Does anyone know if the Logitech extreme digital 3D will work on the FIRST robotics systems? If not, does anyone know where to find ambidextrious joysticks that will work.
Thanks.
Unread 13-02-2005, 20:42
Re: Joysticks....
Any joystick that follows the old 15-pin game port pinout should work. The only place I know of to find them reliably is eBay.
Unread 14-02-2005, 08:11
Moloch's Avatar
Re: Joysticks....
I found a 15 pin joystick but when we plug it into the OI all four of the wheels spin. Is there something in the program that I need to write??
Unread 14-02-2005, 09:04
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Joysticks....
Look for an adjustable potentiometer or wheel on the joystick for the x and y Axis's. Normally there is a small calibration wheel that is used to adjust the joystick so it can be offset from the origin and that is what it sounds like your problem is. If you can find those calibration wheels and center them your problem will probably go away.
-Michael Dessingue
Unread 14-02-2005, 09:19
Moloch's Avatar
Re: Joysticks....
Thanks. I will try that as soon as I get to my robot!
Unread 14-02-2005, 09:54
Moloch's Avatar
Re: Joysticks....
There are no trims on this joystick. Any other options to go for??
Unread 14-02-2005, 11:56
Re: Joysticks....
Use the Dashboard program to make sure the joystick controls the x and y axis values. If the values change enough (a difference of 200 or more from min to max) when you move the joystick, it should work okay. Then calibrate the Victors to match your joysticks.
Unread 14-02-2005, 12:29
Moloch's Avatar
Re: Joysticks....
As soon as we turn on the robot all four wheels begin to spin, but when you move the joystick nothing changes.
Unread 14-02-2005, 13:05
Re: Joysticks....
Use the Dashboard program to see what does change, if anything.
What kind of joystick are you using? The Logitech Extreme Digital 3D you mentioned at first is a USB device. It appears to have a 15-pin game port adapter and associated software driver to let it connect to a Windows PC lacking hardware USB support, but it does not use the standard "15-pin game port pinout". The IFI Operator Interface cannot work with it.
Unread 14-02-2005, 13:09
Moloch's Avatar
Re: Joysticks....
Thanks. It seems that the only joysticks that do work are the old flight sticks you can get off of E-Bay...
Unread 14-02-2005, 15:57
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Re: Joysticks....
where is a diagram of the buttons and their aliases/lines of code used to access them.
I need to know what the aux. switches in the code are called.
Unread 14-02-2005, 17:23
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Joysticks....
Be careful... just because a joystick or gamepad has a 15-pin connector doesn't mean that it will work with the OI. Many modern joysticks, even with an old-school connector, use an incompatible protocol, such as the Microsoft Sidewinder. The older the joystick, the more likely it will work, but there are no guarantees.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-03-2005, 20:58
raptere raptere is offline
raptere is an unknown quantity at this point
Re: Joysticks....
on the topic of fifteen pin joysticks i bought a new set of joysticks with the game port but they are labled as digital joysticks. i took apart one of them and found that the normal properly operating sticks have a single variable resister for each axis and the wires go straight to the connectors. The digital ones have one sensor with two separate wires comming out of them but insted of the wires going to the plug they first go to a computer chip, and then to the connector. I find my self wondering if the circuit board needs power to operate but i am finding no changes out of the connectors any ideas that can be shared?
Thanks everyone,
Eli
Raptere
number of joysticks Waste General Forum 21 27-01-2005 15:04
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Other joysticks tml240 Programming 8 05-02-2004 15:09
