Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 14-02-2005, 10:48
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
You know what sucks?
When the wheels on the left and right side of your robot rotate at the exact same rate... (using encoders and PID velocity control, AND we counted rotations to verify they spun at the same speed)
And your robot STILL doesn't go straight...
The best part is: It goes as straight as a bullet in REVERSE, but not forward.
8 days to get this one sorted out!
I blame the mechanical guys , because one could guess that this is the difference between shifting your weight over nice fat grippy wheels (reverse) vs shifting your weight over slippery omnis (forward), combined with robots having no suspension to keep power down on all your wheels nicely, and a frame which is probably not perfectly flat at all corners.
So why is this in the programming forum?
Because during 5th week, EVERYTHING becomes a programming problem... hahah.
"Just make it go straight"
-SlimBoJones...
Unread 14-02-2005, 12:19
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: You know what sucks?
-SlimBoJones...
So true. Motor swings arm around too fast with no load? Gear it down some? Have a transmission? No. Mount a gyroscope and use a PD loop to keep it at a reasonable rate of rotation.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 14-02-2005, 14:17
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Slimbo quit whining and fix the programming. All this wasted time is why we are having problems. We build the perfect robot and what do you do but make in go in circles.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 14-02-2005, 14:28
AKA: Mr. Lim
Hey!
I'll do my best, but I'm this --><-- close to telling our drivers they're NASCAR styling it this season...
"Sorry boys and girls, left turns only!"
-SlimBoJones...
Unread 14-02-2005, 16:05
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Your job as the programmer is to compensate for all of the SLOP, BACKLASH, FRICTION and CG miscalculations the mechanical team has built into the robot. And by the way, you only get one week to fix their five weeks screw-ups.
Happy programming
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 14-02-2005, 22:07
occra 23.
AKA: ryo
None #1481
it never mattered to me how straight it goes when you apply full forwars on both sides. it has always been more of a driver thing to fix. they just hafta drive it enough to be able to drive it in a straight line with their eyes closed. which really isnt too hard once you learn what your robot feels like doing at different times. and anyways, ive found i havent had to drive long distances completely straight anyways. things/robots get in the way way to often
Unread 14-02-2005, 22:12
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You should feel lucky, SlimBo. A lot of us have yet to dig into the programming.
Team 1257
Unread 14-02-2005, 22:45
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Happy programming
I happened to be a programmer, and ttedrow is right.
Last year we had to compensate for the differenced between the motors on the left and the right, but it is probably easier to fix by programming it, compared to rebuilding it.
- from B B frank
Unread 14-02-2005, 22:47
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Yeah, at least your robot is in some shape to have software problems.
Unread 14-02-2005, 22:56
Ah, but in the first few seconds of the match, the only driver is the code crafted by your team's programmer(s). If the robot has a turning bias that's not easily characterized, the programming job becomes a lot more difficult.
Unread 14-02-2005, 23:04
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Vacuum's suck... regardless, our 2004 robot did that; it horribly drifted towards one side (I think it was left), but when thrown into reverse, it went straight. I've always thought this to be a mechanical problem, so I took our gearboxes apart and saw that the coupling between the motor and gearbox was grinding against the housing. I got rid of all the friction (and these were off the shelf gearboxes) and it still had that horrible drift... Anyways, lots of driver practice fixed the problem -- so stop pointing fingers at the mechanics and programmers!!! =D
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 19-02-2005, 10:07
Embok's Avatar
Embok Embok is offline
Seriously now, who is JVN?
AKA: Eric Rene de Cotret
#0188 (Blizzard)
Embok is on a distinguished road
You forget that with Steve even in the first week, it is a programming problem.
Unread 19-02-2005, 10:53
occra 23.
AKA: ryo
None #1481
ur right! i completely forgot about that lol. so maybe you do need a robot that can go straight. ive got a lot to learn...
Unread 19-02-2005, 15:58
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
do u have the pwm cables hooked up right, in the code, there seems to be diffrent settings set for each one, maybe check that out, lol, i guess i better get back to working on everything, last day, and no one else has really showed up....
Unread 19-02-2005, 16:25
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
guys you are forgetting a cardinal rule about motors, they have full power when applied to the positive, and when you apply full power negative, they spin slower...it was painfully obvious w/ the old drills.
You also might have a wheel out of alignment, aided with the tracking of your motors, may be why you are doing arc's
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Favorite quotes on CD gear! Astronouth7303 Chit-Chat 47 05-09-2004 14:52
PBASIC sucks maDGag Programming 31 29-01-2003 03:16
Poetry sucks evulish Chit-Chat 16 14-11-2002 11:18
This sucks! Team238-aholic Championship Event 0 23-04-2002 20:00
10 Reasons Why FIRST sucks. Anton Abaya General Forum 20 11-12-2001 14:32
