Go to Post The next hint will be game hint #3. Everyone will go crazy trying to figure out which of the fake hints was hint #2. - Joe Ross [more]
Unread 05-02-2005, 17:37
MarkVH's Avatar
MarkVH MarkVH is offline
AKA: Mark VanHaitsma
FRC #0288 (RoboDawgs)
MarkVH is on a distinguished road
Camera not working when connected to robot
I am using the user default code ver2.4. How do program it to track a color?
Unread 05-02-2005, 17:56
Dragnass's Avatar
Dragnass Dragnass is offline
#1345 (Platinum Dragons)
Dragnass is an unknown quantity at this point
Re: Camera not working when connected to robot
Did you Calibrate the colors first??
Unread 05-02-2005, 18:08
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Lightbulb Re: Camera not working when connected to robot
First you need to calibrate to get the correct exposure settings. Put these into user_routines.c where indicated. Then, connect your left motors to pwm12 and the right motors to pwm11. The default 2.4 code uses a one joystick drive (port 1 - use the calibration wheels on the joystick to get the motors to neutral) but you still need two joysticks connected to the OI. Once you load the code, press the trigger on the joystick you have connected to port two. This will cycle through the five colors and light up the red LEDs on the OI. They go in order from top to bottom :Yellow, Green, White, Red, Blue. If you calibrated correctly and have the servos mounted, each time you select a new color the camera should recenter itself and then begin tracking the color.
Edit: Also make sure your converter card, power wire, and backup battery are connected correctly.
Unread 07-02-2005, 17:50
MarkVH's Avatar
How do you tell the camera what color to track?
Unread 09-02-2005, 00:37
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Call the function camera_find_color(); and in the parentheses put the color you want it to find in capital letters. I dont know if the caps matter but I know it works with caps.
Unread 14-02-2005, 15:40
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
Searching for the root of our problem, i tried to do all of this... but didn't work. All the connections seems to be fine (TTL on RC, pwm on TTL and Camera, pwm on RC and Camera, backup battery full charged, etc.)...
BUT DIDN'T WORK!
I really don't know what can I do to the camera give some life signal...
OH! Almoust forgotting... With the default code 2.4, the camera keep a green and a red LED on, but the terminal window of the IFI loader says: "Camera not Found! please check, power and cable connections."
and in the OI, all the four red lights from PWM Outputs are blinking, even if I press the triggers, or any button on the joysticks... PLEASE HELP!!!
If someone wants more information, like photos of connections or any other doubts, just ask me =D
Ignore alien orders.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
How much do you design before kickoff? Allison K General Forum 19 07-12-2004 21:32
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
