Go to Post what would we do without brandon? - Arefin Bari [more]
Unread 14-02-2005, 16:05
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: You know what sucks?
Your job as the programmer is to compensate for all of the SLOP, BACKLASH, FRICTION and CG miscalculations the mechanical team has built into the robot. And by the way, you only get one week to fix their five weeks screw-ups.
Happy programming
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 14-02-2005, 22:07
occra 23.
AKA: ryo
None #1481
it never mattered to me how straight it goes when you apply full forwars on both sides. it has always been more of a driver thing to fix. they just hafta drive it enough to be able to drive it in a straight line with their eyes closed. which really isnt too hard once you learn what your robot feels like doing at different times. and anyways, ive found i havent had to drive long distances completely straight anyways. things/robots get in the way way to often
Unread 14-02-2005, 22:56
Ah, but in the first few seconds of the match, the only driver is the code crafted by your team's programmer(s). If the robot has a turning bias that's not easily characterized, the programming job becomes a lot more difficult.
Unread 14-02-2005, 23:04
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Vacuum's suck... regardless, our 2004 robot did that; it horribly drifted towards one side (I think it was left), but when thrown into reverse, it went straight. I've always thought this to be a mechanical problem, so I took our gearboxes apart and saw that the coupling between the motor and gearbox was grinding against the housing. I got rid of all the friction (and these were off the shelf gearboxes) and it still had that horrible drift... Anyways, lots of driver practice fixed the problem -- so stop pointing fingers at the mechanics and programmers!!! =D
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 19-02-2005, 10:53
occra 23.
AKA: ryo
None #1481
ur right! i completely forgot about that lol. so maybe you do need a robot that can go straight. ive got a lot to learn...
Unread 19-02-2005, 15:58
h0x4r h0x4r is offline
h0x4r has a little shameless behaviour in the past
do u have the pwm cables hooked up right, in the code, there seems to be diffrent settings set for each one, maybe check that out, lol, i guess i better get back to working on everything, last day, and no one else has really showed up....
Unread 19-02-2005, 16:25
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
guys you are forgetting a cardinal rule about motors, they have full power when applied to the positive, and when you apply full power negative, they spin slower...it was painfully obvious w/ the old drills.
You also might have a wheel out of alignment, aided with the tracking of your motors, may be why you are doing arc's
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 14-02-2005, 22:45
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Happy programming
I happened to be a programmer, and ttedrow is right.
Last year we had to compensate for the differenced between the motors on the left and the right, but it is probably easier to fix by programming it, compared to rebuilding it.
- from B B frank
Favorite quotes on CD gear! Astronouth7303 Chit-Chat 47 05-09-2004 14:52
PBASIC sucks maDGag Programming 31 29-01-2003 03:16
Poetry sucks evulish Chit-Chat 16 14-11-2002 11:18
This sucks! Team238-aholic Championship Event 0 23-04-2002 20:00
10 Reasons Why FIRST sucks. Anton Abaya General Forum 20 11-12-2001 14:32
