Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 14-02-2005, 19:56
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Need Help with Encoder - Won't Count Clicks
I need help getting these encoder clicks to work in the 2005 FRC. It works fine in the demo encoder.hex. But I can't it to work with the current frc.
What am I doing wrong??
Thanks
Adam
Unread 14-02-2005, 20:03
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Need Help with Encoder - Won't Count Clicks
I am not sure whats included inside of the 'Initialize_Encoders();' function, but I believe that you need to initialize the interrupts first by running function 'Initialize_Interrupts();' before you run 'Initialize_Encoders();' inside of function 'User_Initialization()', like so:
void User_Initialization (void)
Putdata(&txdata);			 /* DO NOT CHANGE! */
- from B B frank
Unread 14-02-2005, 20:55
Kingofl337's Avatar
AKA: Adam
Error - could not find definition of symbol 'Initialize_Interrupts' in file 'C:\FrcCode2005v2.4\user_routines.o'.
Errors : 1
Unread 14-02-2005, 21:30
Electrical Engineer
Rookie Year: 1995
Errors : 1
Then I would suggest that you add it...
Mike Betts
As easy as 355/113...
Unread 14-02-2005, 21:31
AIBob's Avatar
AI Programmer
Sorry, thats just in my teams code I guess, I do not remember the default code, here is what the function looks like:
void Initialize_Interrupts(void)
// initialize external interrupt 1 (INT2 on user 18F8520)
TRISBbits.TRISB2 = 1; // make sure the RB2/INT2 pin is configured as an input [108]
INTCON3bits.INT2IP = 0; // 0: interrupt 1 is low priority (leave at 0 for IFI controllers) [91]
		// 1: interrupt 1 is high priority
INTCON2bits.INTEDG2 = 1; // 0: trigger on the falling-edge [90]
		// 1: trigger on the rising-edge
INTCON3bits.INT2IE = 1; // 0: disable interrupt 1 [91]
		// 1: enable interrupt 1
// initialize external interrupt 2 (INT3 on user 18F8520)
TRISBbits.TRISB3 = 1; // make sure the RB3/CCP2/INT3 pin is configured as an input [108]
INTCON2bits.INT3IP = 0; // 0: interrupt 2 is low priority (leave at 0 for IFI controllers) [90]
		// 1: interrupt 2 is high priority
INTCON2bits.INTEDG3 = 1; // 0: trigger on the falling-edge [90]
INTCON3bits.INT3IE = 1; // 0: disable interrupt 2 [91]
		// 1: enable interrupt 2
It might be in your 'Initialize_Encoders();' routine, so check in there to see if its there before adding another function.
edit:
- if you are adding the function, be sure to set the right interrupts you re using, and if not, make sure that they are set correctly as of now -
How are "Get_Left_Encoder_Count();" and "Get_Right_Encoder_Count()" defined in your code?
And what does your 'InterruptHandlerLow()' (inside of user_routines_fast.c) function include?
- from B B frank
Unread 16-02-2005, 18:30
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
EDIT: we got it working fine
Harker Robotics:1072
http://www.harker-robotics.org
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
quick question: TIMERS Xufer Programming 58 18-03-2004 08:49
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
