Go to Post the political parties should consist of AndyMarkcrats and IFI-icans.... - Josh Hambright [more]
Unread 14-02-2005, 21:29
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Tank Drive
We need help with using two joysticks with a tank drive system. I do believe the default code is only one joystick. If there is code somewhere, documentation, or even your help, it would help greatly, thank you!
Unread 14-02-2005, 21:46
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Tank Drive
Tank drive is very simple to program, and I believe that it is included in the default code, as an option. but here is what you would use as the code:
pwm01 = p1_y;   //change 01 and 1 to appropriate joystick and pwm output
pwm02 = p2_y;   //change 02 and 2 to appropriate joystick and pwm output
Thats basically it...
You put that in the function 'User_Driver' in place of whtever code you used, and its tank drive.
- from B B frank
Unread 14-02-2005, 21:49
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: Tank Drive
In the version of the default code that we use (not sure which one it is), the above code is included under Default PWM Mappings.
Unread 14-02-2005, 22:04
FRC #1706
Team Role: Driver
Re: Tank Drive
I got the default code off of innovation first's documentation part on their website.
Where is the User_Driver function within the code?
Unread 14-02-2005, 22:30
AIBob's Avatar
AI Programmer
Re: Tank Drive
It is located within "user_routines.c".
- from B B frank
Unread 14-02-2005, 22:41
FRC #1706
Team Role: Driver
Re: Tank Drive
AHHH I cant find it anywhere in the thing
there isnt any function it...
Unread 14-02-2005, 22:46
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Re: Tank Drive
Er...it's in Default_Routine, not User_Driver
Unread 14-02-2005, 22:48
AIBob's Avatar
AI Programmer
Re: Tank Drive
OK... my team renamed that too, I just do not remember what we changed from the default code from last year, sorry.
It should be 'Default_Routine()'
- from B B frank
Unread 14-02-2005, 22:55
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: Tank Drive
It is part of a long list which maps the joystick inputs to pwm outputs. Its about ten lines long, they all look about the same (number=number, and its about half or 3/4 the way down user_routines.c
Unread 14-02-2005, 23:05
FRC #1706
Team Role: Driver
Re: Tank Drive
So as long as I hav ethat included it should work?
Unread 14-02-2005, 23:14
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Re: Tank Drive
Depends.
On our bot last year, the motors were placed such that we had to reverse motor output to one side.
So,
pwm01 = p1_y; //put the joystick input to motor output directly
pwm02 = 255-p2_y; //reverse this motor
worked. You might need this depending on how your gearboxes/motors are put in. I'm guessing you'll have to reverse one (try which one) of the motors.
And this is, of course, assuming you are using one motor for left drive and one motor for right drive (no more no less).
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 14-02-2005, 23:17
Re: Tank Drive
Or if you have two motors for each drive (four total) and the two motors on each side are connected via the yellow-red-black PWM cables to one PWM Output on the RC, like we did this year.
Unread 15-02-2005, 06:20
FRC #1706
Team Role: Driver
Re: Tank Drive
Should I comment/delete (not sure what would be better) out the stuff i don't need, like p1_x and p2_x, or does that need to be there for the bot to run?
And Ive only had a little of coding experience but wouldn't making the one motor go backwards be pwm02 = p2_y-255; not pwm02 = 255-p2_y; or did he have it right before?
And one more thing, in Deafault_Routine, there is a section titled, 1 Joystick Drive, and it combines the x, y on one joystick port.. Should i take this out?
Unread 15-02-2005, 07:27
AIBob's Avatar
AI Programmer
Re: Tank Drive
No.... you should leave them, as long as you do not send them to the pwms
No.... if you put in 0, it would leave you with -255, which is not an unsigned char and will give you an error.
Maybe.... You should comment this section out for later use
- from B B frank
Unread 15-02-2005, 09:01
FRC #1706
Team Role: Driver
Re: Tank Drive
Okay I think I got it. Thanks for all of your help.
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
tank drive Stormhammer Programming 11 29-01-2004 23:08
