Go to Post With a little time and practice, I think that most people would find that there is no magic involved in programming. - Dave Scheck [more]
Unread 14-02-2005, 21:08
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
pic: 1403 Teaser # 2
Team 1403 is Proudly Sponsored By:
Unread 14-02-2005, 21:10
Re: pic: 1403 Teaser # 2
This arm was built to be virtually indestructable. We had fun making this arm and I am gonna have a lot of thing using this on the field, especially when you see the manipulator.
GO 1403!!!
Unread 14-02-2005, 21:11
zc923's Avatar
zc923 zc923 is offline
Alumni and College Mentor
AKA: Zubair Chaudary
zc923 has a spectacular aura aboutzc923 has a spectacular aura aboutzc923 has a spectacular aura about
Send a message via AIM to zc923
Just as a side not, the quick grips are not really a part of the arm, just there to mock up the suspected attachment.
"I look at the world and I notice it's turning...
...With every mistake we must surely be learning."
-While My Guitar Gently Weeps
Unread 14-02-2005, 21:12
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I have to say, that it is a very cool arm.
... Would be very nice to know how it works. how much does it weigh?
Unread 14-02-2005, 21:16
zc923's Avatar
One word, pnumatics.
Its aprox. 20-25 lbs.
Unread 14-02-2005, 21:45
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Eww, must take forever to extend multiple times then :-/ Pneumatics can be obnoxious when going that much of a distance, and if you dont use a big cylinder for such a long arm you don't have much strength. I'd be curious to see what happens after lifting one or two tetras, seems like it would take awhile to recharge pneumatics for such a long thing.
Unread 14-02-2005, 21:51
We have a big cylinder and plenty of speed, don't worry. The way the arm set up makes this thing very fast. No worries man...
Unread 14-02-2005, 22:00
zc923's Avatar
If not use properly, yes, but our strategy is pretty much rock solid.
Unread 14-02-2005, 22:04
Robot Lifeguard
True, cause with the limit on air containers we have... and the time it takes the compressor to recharge the system... after 1 or 2 up and down movements, your gonna have to wait awhile for recharge, but like ya said... as long as you plan your strategy around it you'll be good... just don't extend up before you've made sure you caught a tetra, or its a bad day :-p
Unread 14-02-2005, 23:44
roboguy #1 roboguy #1 is offline
Unlicensed "Can Do It All"!!!
AKA: David
#1047
roboguy #1 is infamous around these partsroboguy #1 is infamous around these partsroboguy #1 is infamous around these parts
Send a message via AIM to roboguy #1
Your all thinking to off. It's got to be a sealed arm, air fils inside of it like a telescoping cylinder acutally two onve its extended it will do the standard rotate on a pivot to raise and lower. I'm right I know I'm right. Also think about it this way unless the cylinder was like microscopic bore it would never have toime to extend and retract for every tetra. Once filled topped off for leaks. I'm right I know I'm right.
Unread 14-02-2005, 23:57
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
You would be amazed how much you can do with not much air too. Last year we had a two stage arm, the first stage used two 1.5" x 2ft long rams, and the second stage used one fatty (2"?) ram that was two feet long. We could extend all three on a tank of air, and retract them (pulling the robot off the ground in the process) all within about 6 seconds. That compressor is fast and keep in mind that you can store the air at 120 psi. Additionally depending on how you plumb your pneumatics you can draw air from other rams essentially using them as tanks.
Unread 15-02-2005, 15:11
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
little bit of a change, its 20-25 pounds before we lighted it up. So it'll probably be around 15. The rest of the robot weighs like 80 pounds, so we should be under the limit.
oh and the time it takes for the arm to reach out and retract, you may find very suprising. Its a piece of art.
Unread 15-02-2005, 15:17
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
apparently if you know your right, then you would know thats illegal..You cannot manufacture pnuematic components. so making tubular arms to extend via air in them is illegal. you must use the pnuematics that are allowed. Seriously man, do you think before you post? because it sure doesnt seem so. if you should remain posting, make sure you investigate your answers before you provide them
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 16-02-2005, 14:25
uhhh, your wrong. I Designed and Built it, and your wrong. Just wrong. And have you even used a pneumatic actuator before? They are rarely slow.
pic: 1403 Teaser.... slickguy2007 Robot Showcase 12 28-04-2005 19:43
pic: 45 teaser pic 2 Kyle Love Robot Showcase 7 02-02-2005 23:22
pic: Team 555 Teaser CD47-Bot Robot Showcase 9 28-02-2004 12:36
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
