Go to Post GP makes us all on one and the same team. They understand that in order for any of us to succeed, we need to help out where we can. It is why you will see so many other teams helping a team with a failing robot, buggy software, team strategy, etc. - Al Skierkiewicz [more]
Unread 14-02-2005, 22:02
Carlo Carlo is offline
FRC #0365
Carlo has a spectacular aura aboutCarlo has a spectacular aura aboutCarlo has a spectacular aura about
Send a message via AIM to Carlo
Re: Another CIM Question
Sorry I wasn't more specific guys.... I was crunched on time.
So a better explanation.
Dual motor drive using the "Nothing But Dewalts" transmission setup. Big thanks goes out to Joe and Joe.
The motors are set up so that both will spin in the same direction (Not one in reverse) and linked to our ouput shafts with sprockets and #25 chain. Beings the gearing on the Dewalt transmissions are 12:1, 4:1, and 3:1, we have the additional 5:4 gearing in our sprockets.
The 2.5 inch wheel accounts for our main wheel turning our treads. The problem happens in a straightline, not just turning, so I know it's not a tread dilemma.
It does spin just fine in any gear while up in the air, but with the specs on the CIM motor, it doesn't make sense to me why it wouldn't work on the ground. At approximately 110 lbs this year, we should have no problem, as the torque works out to be higher than our 130 lb robot last year. Unless the Dewalt gearbox's efficiency is under 70% that is.
I imagine the problem is the spike when starting them, but I've got amp meters hooked up and they've pulled 37 at the most.
University of Delaware
Mechanical Engineering- 2009
Dupont Advanced Fiber Systems
cim motor power question Zippiot Motors 16 16-02-2005 20:40
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
