Go to Post The awards may or may not come...but the real trophies are the students. - David Brinza [more]
Unread 14-02-2005, 22:05
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #5010 (Tiger Dynasty)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
pic: (447) Is this legal?
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 14-02-2005, 22:07
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: pic: (447) Is this legal?
Don't think so:
Q&A #1407
Q:Question ID 1179 did not answer the question. After much discussions there has not been a concensus as to whether 1/4" coiled hose can be used for expansion reasons? We would like to see a yes or no answer please.
A:No. It does not pass the 2005 Part Use Flowchart for a fitting or a valve.
But this is allowed:
Q&A ID#1616
Q:Can we coil the provided hose for the pneumatic system our selves?
A:Yes.
And that is what we did...
Ricky Quinones
Director of Sales - VEX Robotics
Unread 14-02-2005, 22:36
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
I made sure of the first answer so no that hose is not legal. Yes we made our own. It's not quite as good as bought but that's how it goes.
I also noticed that it is not the SMC blue hose so again not legal. By what I hear it has to be the blue hose as that is what was supplied in the kit.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 14-02-2005, 22:56
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Our hose was a Opaque black color. I just did our pneumatics today.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 14-02-2005, 23:14
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
How do you coil it yourself? Do you heat it or something? Because I wouldnt think the judges would like to hear that you had heated the hose....
Unread 15-02-2005, 05:36
Ryan Curry Ryan Curry is offline
FRC #0030 (FURY)
Team Role: Driver
Ryan Curry is on a distinguished road
Send a message via AIM to Ryan Curry
We coiled our hose by wrapping it around a piece of PVC pipe, taping it down on the ends, then hitting it with a heat gun set on low. It didn't take very long at all, and coiled beautifully after that.
-Rc
Unread 15-02-2005, 08:33
Grow Up? Why?
There is no rule against heating the tubing, just modifying. It is still tube and it still has the same properties. If you heat it too much it will shrink and give less air flow, so be carefull.
Unread 15-02-2005, 10:40
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Lets go through the 2005 Part Use Flowchart.
Is the part a pneumatic component? YES
Is it an Air Cylinder ordered from the Custom Cylinder Order Form? NO
Is it a purchased fitting or valve rated for 125psi
Or
A purchased cylinder or rotary actuator identical to those available on the Custom Cylinder Order Form? NO
Previous year’s pneumatic components
BUT ONLY
the cylinders and solenoid valves? NO it may not be used
I hope this helps in how to use the flowchart.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 15-02-2005, 11:03
Generator of Entropy
FRC #2973 (The Mad Rockers)
I'd be REALLY careful about this. "It still has the same properties" could be argued against strongly from a safety standpoint, for 2 reasons I can think of:
1) If it remained coiled after you heated it, it permanently yielded. How do you know the plastically deformed material has the same properties (tensile/rupture strength, yield strength, elongation) that it had when it was qualified/certified to its pressure rating? If it hardened locally after heating the material may not redistribute stresses the same way.
2) How do you know that the thickness remained the same after heating? If it shrinks and gives less air flow, it could just as easily expand under load and cause both thinning and a larger diameter. Diameter and thickness are the primary variables in hoop strength - how do you know it's still qualified/certified to its pressure rating?
I think you're pushing this one a little too much Steve. My $.02
Unread 15-02-2005, 11:09
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
We coiled our own air hose for use on our telescoping arm last year, and it passed inspection at a regional and then again at the championship. We used 1/8" airline though. We coiled it by wrapping it around a piece of wooden dowel and taking a heat gun to it very carefully and slowly.
Unread 15-02-2005, 18:20
rufu5's Avatar
20something
Awsome, thank you guys very much!
Guess I will have to take the 10awg wires I ran around it off
-Salvador Dali
Unread 15-02-2005, 21:44
Grow Up? Why?
I have ours coiled with wiring also as I am feeding 2 Festos with one tube so I need wires to activate.
Gary, point taken. I am a stickler for safety so I have checked the tube with 125 lbs pressure after winding. There is also the safety that I have been harping about were coiled tube would be safer than straight. When designing the game they know that there will be issues with tube having to go distance safely. To be able to purchase the proper tube would be the proper thing for FIRST to allow. They allow so many other things when it comes to motors and gearboxes etc why not Pneumatics?
Unread 15-02-2005, 21:52
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I understand their great concern over pneumatics: injuries from high pressure fluid systems are very common. It is just too easy to have a pressure vessel or hose or whatever burst and turn into a projectile. But, I think with the 60 psi restriction, they can be a bit more lax on the other pneumatics rules. Besides the fact that damaged pneumatics stuff will be a lot less dangerous at this pressure, I don't think you can even find any pneumatics components rated for less than that pressure. You'd have to try to screw this one up.
Team 1257
pic: (447) Innovation Break rufu5 Robot Showcase 15 19-02-2005 22:57
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
pic: 33 / 447 CD47-Bot Extra Discussion 1 11-07-2004 14:31
pic: Sleepy 447 CD47-Bot Chit-Chat 4 23-05-2004 21:31
pic: Is this currently legal or considered exotic? CD47-Bot Robot Showcase 10 13-05-2003 01:09
