Go to Post We do FRC to inspire and to be inspired. - Basel A [more]
Unread 14-02-2005, 13:28
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
spike limiting
can I limit the output of a spike?
like making the speed of a motor half of what it initially is?
if I can, how?
Anton Povzner, head&tail of team 1581 programming team... and that's just one of the many reasons for us to loose seriously
Unread 14-02-2005, 13:39
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: spike limiting
Spikes are on and off with straight power in and outputs with no data signal going to them. You cant limit the output of the spike without limiting the input of the spike or by using a voltage regulator after the spike.
-Michael Dessingue
Unread 14-02-2005, 13:55
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Re: spike limiting
I already PMed you Anton, but I will post this so that others who are asking similar questions might understand.
No, you can not limit the output of a spike. The spikes are relay switches, which can only be programmed to be on/off. You either have the full voltage running through them, or none at all.
Here is a simplified version of what would need to be done:
To do what you want to do, you need to use a speed controller, not a relay. Speed controllers have an analog input/output. In your program, their range of values is 0-254, 0 being full reverse, 127 being neutral, and 254 being full forward.
The way a speed controller works is this: based on these values in your program, the speed controller will give pulses of electricity to the motors at a specific wavelength. For a slower speed, the speed controllers will give pulses at a lower frequency, and for a higher speed the speed controllers will give pulses at a higher frequency.
So using a speed controller, set the output to the values that you desire in your program. Using this method, you can easily set a motor to run at half speed.
Hope this helps,
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 14-02-2005, 15:40
Re: spike limiting
And neither of those are legal this year.
Unread 14-02-2005, 17:13
Re: spike limiting
As long as a voltage regulator is under the $200 single electronic item cost i dont see a reason why it couldnt be used.
-Michael Dessingue
Unread 14-02-2005, 22:05
Electrical Engineer
Rookie Year: 1995
Re: spike limiting
This would violate <R53> and <R51> and probably a few more.
Use a Victor. Jaine's explanation was correct and more than complete... End of discussion (I hope)?
Mike Betts
As easy as 355/113...
Spike Connection Gal Longin Control System 4 12-01-2005 13:59
Spike (relay) module pin out coreyjon Electrical 14 05-04-2004 07:05
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
