Go to Post I heard a Lou Holtz quote as an answer to the question of "how do you motivate the unmotivated". He said " You eliminate those who are not motivated." - Scott Ritchie [more]
Unread 14-02-2005, 14:30
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Chain Drive chain
I was wondering how you would go about creating a chain drive chian and then animating it? I seems like a hard thing to do.
Unread 14-02-2005, 23:11
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Re: Chain Drive chain
Do you mean like this?
gears1
gears2
Briefly:
First, you have to model the two distinct links on the chain. Then you define a path using lines or curved lines. Next, you add a Path contraint from one of the links to the spline. In the Motion Tab, check "Follow Path" and reorient the link if necessary. Do the same for the second link. Then just copy and paste. It's tedious, but if someone has a better, more efficient way of doing please share
FYI:
For this scene I did, there were 250+ links and over 350,000 polygons... I even had a Multires modifier on each link and set at 20%.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 15-02-2005, 00:19
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
yeha thats it I just don't know that much about max so i wouldn't know where to start or what somethins are.
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
