Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 15-02-2005, 11:28
HolyOne207's Avatar
HolyOne207 HolyOne207 is offline
Domo arigato, Mr. Roboto
AKA: Brian & Peter
#0207 (MetalCrafters)
HolyOne207 is an unknown quantity at this point
Send a message via AIM to HolyOne207
Re: How do you hook up the camera?
if i dont hook up the ttl port and the pwm cord to the rc controller then i dont get any pwer, why is this?
Legends. Do you want to be one?
Unread 15-02-2005, 11:34
The camera draws power through the cable connected to the RC pwm output.
The PWM output power is only supplied by the small backup battery attached to the RC.
Only the center red wire of the PWM cable is actually used. The camera doesn't care what the PWM is set to in the code.
Unread 15-02-2005, 23:13
SpeakerSilenced SpeakerSilenced is offline
Programming/Electrical Team Member
#0219 (Team Impact)
SpeakerSilenced is an unknown quantity at this point
Send a message via AIM to SpeakerSilenced
Yea i noticed that too, the cam wouldnt work without the battery, i read over the manual again to see if it provided that we needed anything else, and there it was... you need the back up. Hooked it up and the lights went on I was happy .
Couldnt have done it without you Mark
"I want to put a ding in the universe" - Steve Jobs
Unread 16-02-2005, 15:00
HolyOne207's Avatar
AKA: Brian & Peter
i realized that i had put the pwm cord backwards and thats why it wasnt getting any power. lol.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
YMTC: Super Duper Hook! Natchez You Make The Call 7 14-12-2004 20:50
