Go to Post I think the only way I'd die from posting on CD is from my wife killing me. - Koko Ed [more]
Unread 14-02-2005, 21:03
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: Autonomous With Camera
Originally Posted by russell
If you have any questions please ask away, I am quite proud of this relatively simple code and I would love to answer any questions..
Nice job on the code. I noticed that you did not increment your counter though. Also, you said you wrote this off the top of your head, is it the same stuff that is running/tracking your robot now? Thanks,
Josh
Unread 15-02-2005, 00:07
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Hmmmm, good point. It does increment the counter in the program I am running on the bot, and other than that the only differences in the functional part (I never comment my actual code ) are that a) right now it tracks red, not green (for a demonstration tomorrow that could get us nine grand) and b) it doesnt say to put the drive code here, instead it uses a modified version of the default drive code. I realised today that I have not actually put the robot on the floor and had it drive with this code, but I have had it on blocks and it tracks nicely and the wheels definetly turn in the right directions. I will let you know after our demo tomorrow if it actually works .
Unread 15-02-2005, 13:44
#0316 (LuNaTeCs)
That demo sounds sweet, hope that went well for you. I have seen our robot a total of 2 times, so its a bit tough for me to experiment with the code, so I appreciate your help. I still dont understand exactly what is going on with the camera, but I think I know enough now to scrape an auto mode together. I had tested something similiar to your code, but the bot may have been tracking the wrong direction or something, it was acting weird. I dont like the way the default camera code sets turning/forward speed so I think I am just going to make my own code. Again, thanks, and good luck
Josh
Unread 15-02-2005, 23:25
russell's Avatar
#1430 (WRONG)
Ah. Well, the demo thingy is over and the bot sort of worked. But like I said I wrote that code I posted from memory, and come to find out I would have been better off using that, as in my code for the bot I neglected to put an else to stop the motors. Ever seen what a robot can do to a vending machine? Actually it hit the side so nothing actually broke but it was still cool. As it was though the people were still very impressed and I think we will get the money, I was just very annoyed with myself. Anyway, yeah once I fixed that it worked just fine.
Unread 16-02-2005, 14:57
HolyOne207's Avatar
HolyOne207 HolyOne207 is offline
Domo arigato, Mr. Roboto
AKA: Brian & Peter
#0207 (MetalCrafters)
HolyOne207 is an unknown quantity at this point
Send a message via AIM to HolyOne207
im sure that someone has asked this before. but what are the numerical values for the range of the servo on the camera? is it -127 to 127 or what? is it 0 to 254 like the robot? need some help with this please.
Legends. Do you want to be one?
Unread 16-02-2005, 23:52
russell's Avatar
#1430 (WRONG)
It is the normal 0-254 type number, but the range is somewhat decreased, I think the functional range is something like 47-212 or something along those lines. It says in one of the documents in the getting started file.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
