Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 15-02-2005, 13:19
farmer farmer is offline
Tired Mentor
AKA: Matt
#1108 (Panther Robotics)
farmer is an unknown quantity at this point
Help with auton switching code
Late night coding isn't working. We hooked up a binary switch to 4 digital inputs(tied to ground). And added the following code as a test;
void User_Autonomous_Code(void)
static unsigned int mode = 0;
/* Initialize all PWMs and Relays when entering Autonomous mode, or else it
will be stuck with the last values mapped from the joysticks. Remember,
even when Disabled it is reading inputs from the Operator Interface.
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
mode = ((8*!digital_io_04) + (4*!digital_io_03) + (2*!digital_io_02) + (!digital_io_01));
/* mode = 2; */
switch ( mode )
case 0: /* Do nothing */
break;
case 1:
time++;
if (time < 114) {
pwm04 = 150;
else if (time < 152)
pwm04 = 127;
relay4_rev = 0;
else if (time < 570)
pwm01 = 127;
pwm03 = 127;
break;
If we set "mode" equal to 2 or any other number the switch code works fine. But apparently the binary to digital conversion setting "mode" is not because the robot doesn't move. Thanks for any help.
Unread 15-02-2005, 13:48
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
Re: Help with auton switching code
One thing I would do would be to change your digital_io_0X to rc_dig_in0X in the code. (if attached to the RC, I am assuming). Good luck
Josh
Unread 15-02-2005, 14:27
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Right. The digital_io_** is for setting a digital pin to input or output. You have to use rc_dig_in** or rc_dig_out** to actually assign or receive its value.
Unread 15-02-2005, 15:30
Tired Mentor
AKA: Matt
Josh
I knew that! Just testing everyone...yeah right. I'll make that change and give it a try. Thanks a bunch!
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
