Re: Can we load 2004 code?
I do not believe there are any rules against using last years code, atleast I did not find any. So as long as it works, you can use it.
Make sure you are using MPLAB v7.0 IDE, if not then that may be the problem, and I recommend you install it. |
| Best Way To Insert Autonomous Code Into Default then load help.? :-)? | gemccnp | Programming | 2 | 05-02-2005 18:58 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Please Help... Code for 2004 robot | Padfoot Black | Programming | 2 | 18-02-2004 17:07 |
