Go to Post It's the corollary that you pick them no matter what shape they start the event in. Pink is known for showing up at their 1st regional with the robot in an unfinished state. And somehow, magically by the end of qualifications it just works, and they win. - Nuttyman54 [more]
Unread 12-02-2005, 18:43
Fishdude404's Avatar
Fishdude404 Fishdude404 is offline
The fish king!! MUHAHAHAHAHAHAHAHAH
AKA: Andy Hsiao
None #1510 (Westview Robotics)
Team Role: Scout
Fishdude404 is an unknown quantity at this point
Send a message via AIM to Fishdude404 Send a message via MSN to Fishdude404 Send a message via Yahoo to Fishdude404
Where can i purchase a Gyro?
Ok, my team has finally decided to buy a gyro. We want to know what our restrictions are. I've gone over the rule book a couple of times, and i don't see it. If you guys could tell me where to find the stuff on buying a gyro, please tell me. If you'd like to post up directly, that would be fine too :-D
----My Setup----
-Tippmann A-5
-E-grip
-J&J 14" Ceramic Barrel
- Two wrongs don't make a right, but three lefts do
- If I agreed with you, we'd both be wrong
- Happiness is like peeing in your pants. Everyone can see it, but only you can feel it's warmth.
Unread 12-02-2005, 18:45
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: ASAP PLEASE!!!!!!!!!!!!!!11
Make sure it fits through the parts flow chart That's about all the help I can offer...Did you search through the questions and answers though and here at Chief Delphi?
Also try being more descriptive in your titles.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 12-02-2005, 18:46
AKA: Andy Hsiao
Team Role: Scout
lol, sry about that. My thread name is just to attract people to come here. Caps usually get more people to come because our eyes mostlikely are more attracted to things that look different than everything else. But back to topic.....
----My Setup----
-Tippmann A-5
-E-grip
Unread 12-02-2005, 18:49
Running Riot
AKA: Patrick Cloke
Unfortunatly caps usually just piss people off - it represents yelling or screaming so...use it sparingly.
According to our mentor - you can use any gyro that fits within the costs reqs.
FIRSTsearch
Unread 12-02-2005, 18:54
AKA: Andy Hsiao
Team Role: Scout
ah, thank you.
----My Setup----
-Tippmann A-5
-E-grip
Unread 12-02-2005, 19:06
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please check the following thread.
http://www.chiefdelphi.com/forums/sh...ad.php?t=33615
-Michael Dessingue
Unread 15-02-2005, 16:18
gifted4u2 gifted4u2 is offline
Project Engineer
AKA: Tony Merolla
#0048 (Delphi ELITE)
gifted4u2 is an unknown quantity at this point
Re: Where can i purchase a Gyro?
You may purchase the gyros directly from Analog Devices, www.analog.com or digi-key, www.digikey.com. Analog Devices provides evaluation boards, for their gyro product line, which will let you wire it fairly easily.
The parts of interest are the ADXRS300EB, the ADXRS150EB, and the ADXRS401EB. These are the evaluation boards and have the following sensitivity: 300°/sec, 150°/sec, and 75°/sec, respectively.
I just checked digi-key's site and the 150EB is in stock.
I would recommend going to Radio Shack and buying a soldereable breadboard. Actually buy a 20-pin IC socket (also at R Shack) and solder it to the board. In this way, you can easily remove the sensor. Solder a PWM cable to the breadboard, as described by Kevin Watson, http://kevin.org/frc/. You should be good to go.
Updated: Example Gyro Interface Code Kevin Watson Programming 2 28-03-2005 04:36
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
No Signal From Gyro colt527 Programming 12 19-10-2004 07:30
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
