Go to Post At one of the registration days at the beginning of the year I actually made a sign saying: "I'm not smart isn't an excuse". - Mr. Pockets [more]
Unread 15-02-2005, 15:21
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Can we load 2004 code?
Right now we are experianceing an ineresting problem. Our FRC will not take the 2005 default codes once we compiled it. We can load the FRC_default.hex fine for both version 2.2 and 2.4. After we recompile the code to a FrcCode.hex, it will not work! We get the code error light and no outputs. We tried to load the 2004 code and it worked fine! We dont plant on using the camera (Busted) so the 2004 code would be fine.
So does ne one know a solution to the problem?
Or can we just use the 2004 code?
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 15-02-2005, 15:24
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Can we load 2004 code?
I do not believe there are any rules against using last years code, atleast I did not find any. So as long as it works, you can use it.
Make sure you are using MPLAB v7.0 IDE, if not then that may be the problem, and I recommend you install it.
- from B B frank
Unread 15-02-2005, 17:13
AKA: Ken Colton
FRC #0527
Updated to v.7.0 not the problem
FIRST Volunteer
kcolton@gmail.com
Unread 15-02-2005, 17:36
AIBob's Avatar
AI Programmer
This might be it:
http://www.chiefdelphi.com/forums/sh...RC_default.hex
Originally Posted by GregC
Erm, when you compile, the compiler makes a new file called FrcCode.hex every time you compile.
FRC_Default.hex is just the pre-compiled default code that they included in the zip file with the source code.
- from B B frank
Unread 15-02-2005, 17:52
In order to compile the 2005 default code, you probably need to be using a newer version of the compiler, not just the latest IDE. The immediate code error is a common symptom of printf issues, and you might have old libraries installed.
Unread 15-02-2005, 19:48
AKA: Ken Colton
FRC #0527
Originally Posted by AIBob
No, FrcCode.hex is there and that is what we load, its just we get a weird code error. As if we were using too many variables, exept its the default code. To my understanding we had the latest compiler, here is an update though, i went to a compthat had last years compiler and compiled the 2005 no cam default code. I load it and it works ... but the analog values are messed up. We have a pot hooked up and instead of the normal 0 -1024 we get 4-7 at random. I will try reinstalling the compiler tommorow and let u guys know how it goes.
FIRST Volunteer
kcolton@gmail.com
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Please Help... Code for 2004 robot Padfoot Black Programming 2 18-02-2004 17:07
