Go to Post Though winning is not the end, that doesn't mean it's not important. - Michael Corsetto [more]
Unread 15-02-2005, 18:32
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Receiving info from OI to select autonomous mode
void SelectAutonomousProgram(void)
if (autonomous_mode) 	//AUTONOMOUS MODE IS ACTIVE
	if (automode_LED == 0)
		automode_LED = 1; //Turn on the autonomous LED when autonomous mode first starts
		DriveNeutral(); //Stop the drive motors.
		//Do other initial autonomous initialization stuff.
else		//MANUAL MODE IS ACTIVE
	 if (automode_LED == 1)
		 automode_LED = 0; //Turn off the autonomous LED
		 DriveNeutral();	 //Stop the motors
	//Store the status of the LR side select switch
	sideselect = LRsideselect_sw;
	//Store the status of the Auto Drive Disable switch
	autodriveselect = smartdrivedisable_sw;
	//Calculate the autonomous program number set by the BCD switch on the button box --> positions 0-7 are valid. 8-9 are not
	autocode = (autoselect0 * 1) + (autoselect1 * 2) + (autoselect2 * 4);
} //End SelectAutonomousProgram
See the above code for reference - it's what I used last year. I call the SelectAutonomousProgram routine from Process_Data_From_Master_uP. To store any OI switch-driven settings I want to make available to the program once the match starts, I create variables (i.e. sideselect, autodriveselect, autocode) and write the status of the OI switches to them while the robot is in human control mode (which it is when it's powered on and disabled before match start). When autonomous mode starts, these variables are still available to the autonomous code while the OI switches, joysticks, etc. are being ignored. This routine also sets initial robot behavior when the bot first comes out of autonomous mode.
This year, we're using a 3-position toggle switch (wired to an analog input with the help of 22k and 47k resistors) and a BCD thumbwheel switch (8 distinct program options that consume three digital inputs) to yield 24 different autonomous program possibilities. The likelihood of me having the time to program our robot to do 24 different things in autonomous is almost nil, but that's beside the point.
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
