Go to Post Come on guys, its not like it's rocket surgery or anything. - hallk [more]
Unread 15-02-2005, 19:28
Springs, Bungees, Counterweights
I've been watching this board for a couple of weeks and haven't seen a proposed design for an arm that uses either a counterweight or a spring system on the arm itself.
The problem with a counterweight, of course, is that if it is mounted on the arm it raises the CG and does not contribute to the other functions of the 'bot. I suppose the counterweight could have been mounted on a 1/2-height tower using a 2-1 pulley-and-cable system, but that would be clumsy, still add weight up high, and only apply half the downward force as a weight connected through a 1-1 purchase. Of course, if there were a backwards-extending arm just as long as the main arm, you could hang a fairly small weight on the back (see construction cranes). You would still have the high CG problem.
If you committed to a backwards counterbalance arm as long (or almost as long) as the main arm, you could use bungee cord material or a spring to store energy when the arm is descending that could be used to help lift the arm-and-tetra. There are some issues to be solved regarding the effective length of a spring and whether it could be used over the effective length of the arm's motion, but there are ways to work around this. A spring-over-shaft design, sort of like a roll-up garage door spring, might work pretty well.
If you think about it for a few minutes, it would be trivial to design a counterbalance that could be extended automatically after measurement.
Anyway, our team rejected the concept of counterbalancing forces (grumble, grumble), and went with a straight lifting arm system. I am curious if anyone is planning to use this sort of stored energy (smart teams), or considered it and rejected it. Talk amongst yourselves.
Unread 21-02-2005, 02:39
ClicheCow ClicheCow is offline
AKA: Jordan Bentley
ClicheCow is an unknown quantity at this point
Send a message via AIM to ClicheCow
Re: Springs, Bungees, Counterweights
We tried putting on a large spring to assist in lifting tetras yesterday. We were hoping that it would stop us from destroying worm gears, as it took off 1/6th of the downward force on the loaded arm. Unfortunatly, we then preceded to destory another worm gear.
Unread 21-02-2005, 02:41
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
We use a spring on our arm with great success. However, i am unable to find any pictures of the mechanism just yet. I would say that springs are the way to go, they are light and provide the force needed.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 24-02-2005, 11:17
AKA: Dr. Brooks
no team (WRRF)
We use a pair of springs made of surgical tubing to cancel the
force on an arm that tilts at the base of the robot by means of a
screw. Because sin(x) is approximately x for small angles, we
get quite good force cancellation and the tilt motor runs at free
speed.
We also use surgical tubing to help lift the heavier section of
a telescopting tube setup, but in this case we tune the spring to
cancel the force at a spot we think we will likely spend a lot of time
at. We would need a constant force spring, lifting 16 pounds,
to do better than that.
Worm gear life is a problem, we have to do everything we can
to extend gear life.
Unread 24-02-2005, 11:22
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Here's our counterweight for the shoulder of our arm:
It only helps us once the arm is past vertical, but there is bungee on the other side to balance it out.
-Paul
Unread 24-02-2005, 21:52
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
We use a spring to help counter balance. It gives a maximum counter-balancing torque of 42 lb-ft with the arm at 110 degree from vertical, about 38 lb-ft at 90 degrees.
Unread 25-02-2005, 01:54
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Our team decided that counterbalancing was an absolute must. Our arm has a constant-force gas spring to help counteract the weight. Unlike most other springs that exert a force proportional to the distance compressed/extended, our gas spring exerts a constant 225 lbs in every position. A simple sum of moments calculation is done to figure out the distance to mount the spring.
The arm is designed so that one tetra completely balances the arm and unloads the motor (van door). An empty arm means the motor works a little to keep it down and two or more tetras means the motor works to keep it up. We have found this to be highly effective as the motor runs a lot cooler than arm designs in previous years.
You can see it here.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 25-02-2005, 02:43
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
We are using springs. Without the springs we risk buring out our van door motor trying to hold a tetra up even with our arm not extended. So we added springs to the back of the arm and now we risk burning the motor trying to hold the arm down.. Actually the braking on the victor holds it in place nicely as long as the robot is on, but we have to turn the robot on to make the arm stay down. Makes storage more interesting.
Unread 25-02-2005, 08:26
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
We on team 343 are using a heavy duty bungie as a counter balance on our lifting mechanism. You can see pictures on our site, www.metalinmotion.com. The bungies are tucked into the diagonal supports (they're white with blue stripes). They keep the current draw on the fisher price motors down around 10 Amps. For a closer look come by our pit at Florida, Palmetto or the Championship.
Have a great Season!!
- Gene Falendysz
using gas springs? needed? ajlapp Technical Discussion 2 20-01-2005 21:25
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
springs hi_im_sean Technical Discussion 4 23-01-2003 19:05
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
