Go to Post If the refs are not calling something that you think should be called, you have to adjust your play style to deal with it. - Rob [more]
Unread 09-02-2005, 17:02
GAT-X105 STRIKE's Avatar
GAT-X105 STRIKE GAT-X105 STRIKE is offline
GAT-X105 STRIKE can only hope to improve
Hall Effect Sensors
Where is the program and where do you plug them in??
Unread 15-02-2005, 20:09
Re: Hall Effect Sensors
Need help...
Unread 15-02-2005, 23:25
the_undefined's Avatar
the_undefined the_undefined is offline
German FES
AKA: Felix Geisendörfer
#1648 (Gearbox Gangstas)
the_undefined has a spectacular aura aboutthe_undefined has a spectacular aura about
Hmm what do you mean is the program? You mean a code example?
Use Kevin Watson's Navigation Demo here and add a printf() for your Hall Effect Sensor output.
-> http://kevin.org/frc/
Where to plug it in?
You can decide that by setting up your code differntly.
In Kevin Watson's Demo it is:
1) The left encoder's phase-A output is wired to digital input
one and the phase-B output is wired to digital I/O six.
2) The right encoder's phase-A output is wired to digital input
two and the phase-B output is wired to digital I/O 8.
Read the Readme Files that come with it and you should be fine,
I hope that helps
bye
Felix@1648
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
