Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 16-02-2005, 00:32
halomaster69 halomaster69 is offline
halomaster69 is an unknown quantity at this point
Exclamation Wiring issues, help needed
hi, this is the head of the electrical subteam on team #1505 Roybotics. This is our first year in the FIRST competition. well we just got done rewireing our electrical board and it doesnt work. before it did, we could test all the systems, we got a new borad lexan, and we got some victors and other stuff. like i said before it worked, not it doesnt. the only thing that we did different was that we didnt put all the victor fans on a single circut, and we wrapped some of the wires in this spiral wire tie thing. when we turned it on, the fans twitched, then nothing, the led on the breaker panel didnt light up or anything. we tested the circuts, the battery had 12 volts, the main buss had 12 volts going through it, the termainals on the breaker board had like 1.2 volts, and i could smell metal heating up, no smoke though, when we unhooked everything all the wires and stuff it worked, it lit up. but with the wires, nothing.
Please post or e-mail me at Halomaster69@gmail.com if you have any info please help.
thank you
Unread 16-02-2005, 01:06
Electrical Engineer
Rookie Year: 1995
Re: PLEASE HELP!!!!!!! faulty wireing, dunno why
thank you
You have wired something up backwards. Pull all breakers except fot the RC. Insure that that power input is correct and then power up. If OK, then insert one breaker at a time to determine the bad circuit.
Mike Betts
As easy as 355/113...
Unread 16-02-2005, 01:10
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
thank you
Check for shorts and correct polarity to all your Victors and Spikes. Check all your connections. Check power before the breaker panel, right where the main power connects to it to see if you actually have 12 volts(+/-) there, if not then there's a loose connection.
-MIke
Unread 16-02-2005, 01:31
Darwin695 Darwin695 is offline
#0008 (Paly Robotics)
Darwin695 is an unknown quantity at this point
Send a message via AIM to Darwin695
Rewire some stuff, you will be fine...
Yes, polarity is key... Often times it is easy to wire a battery backwards, and not notice it because of the anderson connector...
Make sure that your battery is wired correctly...
ALSO
Your victor fan wires do not need to go to the same circuit...
I would recomend wiring the fans to the power terminals on each of the Victors. That way if a breaker to a victor is popping, or you have a short, or bad polarity, you can identify it with the fans (they do not spin in reverse...)
hope this helps... i know it is not fun to have electrical problems a week before ship date....
I build it,
My brother destroys it
Unread 17-02-2005, 17:17
Evilfrog87's Avatar
Evilfrog87 Evilfrog87 is offline
Dave Thunes
AKA: David Thunes
FRC #0093 (New Apple Corps.)
Team Role: Driver
Evilfrog87 is an unknown quantity at this point
Send a message via AIM to Evilfrog87 Send a message via MSN to Evilfrog87
Re: Wiring issues, help needed
Hi
It sorta sounds like the 120 amp breaker is installed backwards.
-Scott(Student Head of Electrical for Team 93, using Daves account)
KP4EVR
Unread 17-02-2005, 19:47
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
I would be careful about things heating up. When you say the board has 1.2V, be advised that the 1.2 V are being 'dropped' accross the board. somthing (like resistance, or a short) is causing the voltage to be dropped. This may or may not be a problem, I don't know how much voltage is suposed to be dropped. To me this sounds like a large number. During the off season, we were driving last year's robot around and the controller kept on telling us low battery. We would switch the battery and it would still complain. We check the batteries and they would all read 12 V +. But we touched the main breaker and noticed it was very hot. Apparently the beaker was dropping atleat 2V. the breaker shouldn't have dropped any, but it didn't cut off like it was supposed to. I have gotten kind of off subject, but make sure that you don't burn anything up. Just because you don't see the magic smoke, doesn't mean it isn't comming out.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 17-02-2005, 20:18
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
it does sound like some wires were backwards. another suggestion would be to use polycarb insted of lexan. poly is much more durable and wont break
Team 302
Unread 19-02-2005, 14:21
408Oxidation's Avatar
408Oxidation 408Oxidation is offline
Head of Electrical Team 408
AKA: Bryan Kitchener
#0408 (Roboticks)
Team Role: Electrical
408Oxidation is on a distinguished road
Send a message via AIM to 408Oxidation
Could be a short or something in the wiring. If you rewired it all the same way that's the most likely problem. Not all the Victor's need to be on the same circuit I know ours aren't.
While we're here...
Anyone had issues with some of the Victors blinking orange rather than completely lighting up? We have one that isn't working at all and just sits and blinks, perhaps something with the PWM cable, but I'm looking for other ideas. We tried it with 5 different PWM's and its hooked up the same as the other 3...Ideas anyone?
Good luck.
-Head of Electrical, 408 Roboticks
UCF Regional woot
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Basic Electrical Wiring Alienvin Electrical 2 18-01-2005 23:24
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
