Go to Post many of the greatest innovation throughout history have come from people who have ignored standard practices and traditional thinking. - jason701802 [more]
Unread 16-02-2005, 03:06
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Auton digital input
kind of confused by some of the things posted. they recommend switching diff auton codes by using if statements to check ditital_input1 (sorry dont remember variable right now) what exactly is digital input 1 hooked up to and/or what is being pressed to set digital input 1 to a value of 1?
also just a thought, can we use switches (as in light switches) and flip them on and off? (dont know too much about how the digital input side wiring goes)
thanks
-Rookie plz bear with me thanks!
Unread 16-02-2005, 03:10
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Auton digital input
digital input 1 is digital input 1 on the Robot Controller (I think, I'm not a programmer...). I believe the recommendation was that you could hook up a switch to a digital port on the RC, then during autonomous mode, have the code check the state of the digital switch and run the corresponding autonomous program.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 16-02-2005, 03:30
Kurayami o Samayou
None #1160
any idea how our electronics girl would wire the switch? i think its you ground one side and connect other to input? btw would it be possible to have a switch on the joystick controller board? (to use as a toggle switch)
Unread 16-02-2005, 08:55
Billfred's Avatar
Billfred Billfred is offline
http://www.ifirobotics.com/docs/rc-r...01-31-2005.pdf
The manual is your friend here...page 10 deals with Digital I/O.
Cheers!
Unread 16-02-2005, 11:18
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
1.Wire a switch to contact the outside 2 pins of the digital input XX.
2. Declare the digital pin as INPUT
3. In code read rc_dig_inXX where XX is the pin.
We have a series of 11 being used.
Unread 20-03-2005, 18:38
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
What method do you use to connect the switch to the ground and signal pins on the rc. The only thing I can think of is hacking up a bunch of pwm cables, but that seems like a waste of cable to me.
our web site
Unread 20-03-2005, 18:44
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
I believe somewhere in the FIRST documentation it says to hack a PWM cable for these. I guess it would be possible to take some small gauge wire and run that from the switches to the inputs, but you would have to make sure that the wires coming to the pins dont short in that small space, and im not sure of the legality. I would just recommend sticking with the PWM cables.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 20-03-2005, 22:23
So buy the connectors and pins that are used in a pwm cable and use them instead of chopping a $5 cable in half. I bought a batch of them from the Hanson Hobbies RC eBay store. It works out to about 60 cents per connector, plus wire.
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
