Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 15-02-2005, 21:59
stevex stevex is offline
AKA: Steve
#0219 (Team Impact)
Team Role: Electrical
stevex is an unknown quantity at this point
Send a message via AIM to stevex
Wiring a switch
When you want to have a switch do something for you, where do you wire it, to the analog/digital inputs on the robot controller, and then sauder the wires onto the pins you need?
Unread 15-02-2005, 22:14
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Wiring a switch
If this is an on/off two position switch, then you wire one side of the switch to the digital i/o ground (black) and the middle pin of the switch to the digital i/o signal (white). Look in software for either a 1 or 0 on that digital port.
If this is more than two positions, then you can do two things: you can wire the black to the middle switch port, and a signal on either side, and use more than one digital port. Or, if you feel, and it's a 3 position switch, you can put +5 on one side, GND on the opposite side, signal in the middle, and wire resistors between each port (I suggest a 50K ohm on each side.) Put that into analog inputs, and you should get 0, 128, and 255. If that was confusing, i can go into more depth, but if this is not your situation, then ignore it.
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 16-02-2005, 07:42
Re: Wiring a switch
Steve,
Sparks outlined a method that is spelled out in the RC and OI manual and you should check there for complete explanation. You can also make a switch that acts like a pot if you need more than one or two positions. We do it all the time. One thing to add, I don't recommend soldering directly to the pins on the RC or OI. If you need to replace it for some reason it will take forever, and the heat might unsolder the pins on the board or do some other damage. If you need to make a connection, you can buy individual pins or you can cut apart a PWM cable and make splices into the wire ends.
Unread 16-02-2005, 08:31
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Wiring a switch
Here are three reasons that I have used switches on FIRST robots:
1. As a limit switch. Place the switch at the end of travel of an arm or mast to shut the motor off.
2. To select autonomous mode options before the beginning of the match.
3. Custom switches placed on the OI for operator controls.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
Free Wiring Diagram! Mike Alighieri Electrical 16 30-06-2003 14:31
