Re: homemade speed controlllers (for school project)
havn't decided yet, it depends how hard it is to make one go backwards....
ideally yes having im'ed mike betts, i'm probably going to be starting this in a couple of weeks (given other stuff gets sorted as well...) and there will m/p be a thread about it then |
i mean a few weeks more from now.... seem to have got overloaded with other stuff ... |
if you know how to use a servo, and understand the concept of resistors and how to read the lines you can make a clumsy mechanical real easy.
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better. |
So what I'm basically sayingis generally speaking a mechanical speed control will run down the battery faster than an electronic one, and it will get very hot. Electronic is better.[/quote]
yea i know but its so simple. not sure he said he was going to use a battery actually. if its unlimited power supply and littel heat isnt a problem id just make a mechanical. |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
