Go to Post Good story telling and animation know no age limits. - BMiller2559 [more]
Unread 13-02-2005, 10:26
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Camera tracks backwards
We have got our camera tracking off the robot. One problem is that when you pick up one of the colored triangles and move in front of camera as look you at the person and they move left, and yiou look at the screen on computer the object moves right.
Is this correct or not? Also the color numbers I have come up with are green 49, yellow 24, red 118, red is iffy it does not find it all time, still have to play with numbers.
thanx and good luck all
Big Daddy
Unread 13-02-2005, 11:16
Re: Camera tracks backwards
Yeah, the GUI screen is rotated 180 degrees. The camera tracks fine anyway.
Red is almost impossible with the mercury vapor lighting at our shop. We have managed to get it to calibrate once, though it has never tracked at all. Since there's no reason for us to seek out red, we're not worried about it. It tracks vision tetra green like a champ.
(Or it used to -- the electrical team tells me they let out the camera's magic smoke after they wired a connector backwards.)
Unread 13-02-2005, 16:41
logicalhippo logicalhippo is offline
AKA: Russell McClellan
#0213 (Dirty Birds)
logicalhippo is an unknown quantity at this point
Send a message via AIM to logicalhippo
you prolly have the camera upside down ;-). you can compensate in software if you need to
Unread 13-02-2005, 20:12
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Check the manual again. There's jumpers that mirror the pan/tilt servo directions. It took me like a week to find this out.
Unread 13-02-2005, 23:48
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
No no no. You are just fine. As long as the camera tracks it doesnt matter, and as Alan said the GUI screen is backwards. The only color we can track reliably is red. Though we always illuminate the target with a work light, so that may be why. It definetly has to do with having yellow walls, blue tables, and lights that the camera seems to think are green... It is actually kind of fun to play with the robot and watch to see which part of the wall it goes to when we tell it to track yellow.
Unread 15-02-2005, 07:15
BobC's Avatar
Big Daddy
I read about the jumper but could not figure out where it is.
Big Daddy
Unread 16-02-2005, 09:51
aziandorkess aziandorkess is offline
no team (Midnight Mechanics)
aziandorkess is on a distinguished road
Send a message via AIM to aziandorkess Send a message via MSN to aziandorkess
The diagram is on ifirobotics.com
Here's a link to the zip file.
http://www.ifirobotics.com/docs/came...d-markings.zip
In the pdf called CMU Cam Assembly, there's a section called mode header. You should put a jumper on the pan reverse or the tilt reverse.
Good luck.
2007 SD Engineering Inspiration Award
2006 SoCal Chairman's Award
2005 SoCal Chairman's Award
2004 Championships Engineering Inspiration Award
2004 SoCal Engineering Inspiration Award
2003 Arizona Judges Award
2003 SoCal Team Spirit Award
2002 SoCal All Star Rookie Award
Alumna of The Midnight Mechanics (03-06).
Unread 16-02-2005, 10:59
russell's Avatar
#1430 (WRONG)
You people didnt read his post. He said the camera tracks fine, its just the immage on the computer screen that is backwards. This is a problem with the software on the computer, and it no way affects the camera's ability to track.
Bob: Dont put the reverse jumpers on the camera, as if you do it will not track properly (assuming it is tracking ok now) The jumper pins run along the edge by where you plug the servos in, but like I said if it is working ok now then dont mess with it.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
camera tracks but no movement from Robot Stillen Programming 4 04-02-2005 17:16
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
