Go to Post Strive for excellence in everything you do, but also recognize it in others when you see it, rather than try to drag it down. - Joe G. [more]
Unread 15-02-2005, 20:51
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Printf acting flaky
I'm having a few issues with calling printf - it sometimes leaves the format string (like %d) in the output. Something like this:
joyx = 127
joyx = 127
joyx = 127
joyx = %d
joyx = 127
etc...
It seems to be random.
Also, it doesn't seem to like to have information pushed at it multiple times through the main loop. Even though I push a \r\n at it (although the same thing happens with either \r or \n) it overwrites the last bit of output. Is there a buffer or something that can hold a limited amount of data? I never experienced any problems like this last year - did something change? I'm sorry if this seems like a trivial problem - but it's driving me absolutely insane.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 16-02-2005, 12:08
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: Printf acting flaky
I had similar problems last year with printf outputs (using printf_lib). This began after I started using Kevin Watson's tracker code.
The problem was solved by modifying a #pragma statement to cause the compiler to save more processor context prior to servicing an interrupt (the trackers used interrupts to process the IR beacons).
Are you using interrupts? Like wheel encoders?
-norm
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 16-02-2005, 12:30
Joel J's Avatar
Joel J Joel J is offline
do you..
What additional contexts? Right now I'm saving PROD, MATH_DATA, and .tmpdata .
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 16-02-2005, 19:47
I'm using a few timer interrupts currently (although not TMR0) and will be using digital input interrupts too.
What else should I save?
Unread 20-02-2005, 11:54
Also, how often are you printing stuff, and how many characters. What is your interrupt rate? What serial drivers are you using?
Unread 20-02-2005, 12:52
I'm printing stuff once every 15 data packets (26.2*15=393 so about every .4 seconds) and it's about twenty-ish characters long. The only interrupt firing right now is the timer 1 overflow interrupt. I'm not using the TTL serial port, and I haven't fiddled with whatever code comes as default for printf.
Unread 20-02-2005, 14:02
Originally Posted by steven114
joyx = 127
joyx = 127
joyx = %d
joyx = 127
etc...
This is a little too flaky for my taste.
Is this from a single printf statement or do you have two identical printf statements printing results in separate spots? The simplest explaination would be two similar printf's, but one with a typo like: printf("joyx = %d\r");
Unread 20-02-2005, 19:20
Same printf.
Printf symbol undefined? Help schenkin Programming 3 08-02-2005 16:14
printf problem miketwalker Programming 7 31-01-2005 13:19
Default Code and printf WilsonDJ00 Programming 2 22-01-2005 16:39
Anyone with a replacement Printf? Larry Barello Programming 5 19-03-2004 02:20
Printf warning during compile? actorindp Programming 4 20-02-2004 17:02
