Go to Post HOSE CUTTER: A tool used to make hoses too short. . - dlavery [more]
Unread 15-02-2005, 07:44
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Electronics visible?
Originally Posted by DarkWombat
So I guess the question is: can we use a protective shielding/hood to protect the electronics during operation, but which can also be easily removed to access the electronics componenets for inspection and while in the pit area?
The answer from this Inspector is: as minimum the LEDs on the RC must be visible without opening/removing anything.
This is due to the time sensitive nature to the competition. The IFI rep checks each robot before each match.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 15-02-2005, 07:56
You can do whatever you think is best but...If an IFI rep or another smart individual can't see the panel when you are having a problem, they won't be able to help. It is wise to cover the RC but when things start acting up, you want to be able to get some feedback and see that all the PWM connectors and sensor are still connected. When you are 30 seconds from the start of a match and are on the field with your alliance waiting for you, do you want to be removing a big metal cover?
As an inspector, I will agree with Mr. Tedrow, we need to see to help you.
Unread 16-02-2005, 09:18
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
Protecting the electronics is a smart idea. However, you are better off using polycarbonate instead of aluminum.
"My favorite programming language is solder."
- R A Pease
Unread 16-02-2005, 09:44
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
lexan is perfect, strong and see through
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 16-02-2005, 12:06
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Unless you're using transparent aluminum. Oh Wait that hasn't been invented yet
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-02-2005, 13:08
http://physicsweb.org/articles/news/8/8/9
Unread 16-02-2005, 23:50
DarkWombat DarkWombat is offline
#0840 (Aragon Robotics Team)
Team Role: Electrical
DarkWombat is an unknown quantity at this point
Thanks for the responses. We're probably going to just mill a rectangular hole in the center of the hood and screw on lexan to cover it. And that aluminum article, even though it's around 6 monhts old, is pretty interesting. It's only a matter of time....
Think....transparent titanium?
Programming and Electronics — Getting Started Sidney San Martín Technical Discussion 7 12-01-2005 15:25
Books on electronics relating to robotics patrickrd Technical Discussion 1 15-05-2004 21:28
Covering Electronics shyra1353 Rules/Strategy 6 24-02-2004 22:23
Professional electronics board assembly [annotated collector's edition] Geoff General Forum 7 17-02-2004 21:57
Question about buying electronics _GP_ General Forum 5 01-02-2004 12:43
