Go to Post Whoooo, just got my wheels from AM! Sometimes it's cool to live in Indiana. - IndySam [more]
Unread 14-02-2005, 21:49
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Syntax Error: externs, structs, and macros
Here's the thing: I'm getting a syntax error in 2 seperate lines that are probably related. I have narrowed it down to the point that I know that it is not the next or previous line.
They are:
BEGIN_MOTOR_LIST(motor_list)
	MOTOR(STRAIGHT,	LeftDrive,	OI_Left,	0,	0,	 0,	 0,	0,	254,	254) //ME! ME!
END_MOTOR_LIST
REF_MOTOR_LIST(motor_list);
Here are the dependencies needed to get this:
#ifdef _MOTORS_H_
#define _MOTORS_H_
typedef enum {NONE,STRAIGHT,POSITION,FISHER} MotorType;
struct motors
	enum Motor type;
	char* pwm;
	char* oi;
	char pot;
	char pot_min;
	char pot_max;
	char pot_center;
	char pwm_min;
	char pwm_max;
	char pwm_change;
#define BEGIN_MOTOR_LIST(name) struct motors rom name[] = {
#define END_MOTOR_LIST                   {NONE, 0, 0, 0, 0, 0, 0, 0, 0} };
#define REF_MOTOR_LIST(name) extern struct motors name[]
#define PTR_MOTOR_LIST(name) struct motors *name
#define MOTOR(type,pwm,oi,pot,pot_min,pot_max,pot_center,pwm_min,pwm_max,pwm_change) {type, &pwm, &oi, pot, pot_min, pot_max, pot_center, pwm_min, pwm_max, pwm_change },
void DoMotors(PTR_MOTOR_LIST(motorlist));
#endif
char LeftDrive, RightDrive, E2;
#define OI_Left  p1_y
(unfortunately, it inserted random spaces)
Enlightenment?
Unread 14-02-2005, 22:54
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Re: Syntax Error: externs, structs, and macros
#define MOTOR(type,pwm,oi,pot,pot_min,pot_max,pot_center,p  wm_min,pwm_max,pwm_change) {type, &pwm, &oi, pot, pot_min, pot_max, pot_center, pwm_min, pwm_max, pwm_change },
Might it be the marked bit?
Unread 15-02-2005, 00:30
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I didn't spot anything wrong off-hand (other than the space noted by the previous poster, but I'm guessing that was a copy/paste problem?). Something you might try to narrow down the problem is pre-processing the C file to see how your macros worked out. There should be a cpp18.exe as part of the MCC18 package - this is the C preprocessor. Just run:
cpp18 {filename}.c -I{path to MCC18 include directory} > {filename}.pre
and it will spit the preprocessed file out to {filename}.pre. That might yield some clues.
Unread 16-02-2005, 15:39
AKA: Jamie Bliss
Originally Posted by Orborde
Nope. That's just from the post. Try as I did, I couldn't get rid of it. But it doesn't exist in the file.
Cool! Thanks! I'll try that!
